Battery ground?
bayou1
Real Name: cliff
Radio: Cobra
Battery ground?
#365732
Post by bayou1 »
In a separate charge system with batteries in rear. Has anyone seen a benefit to running a ground from back battery up front to the alternator. I've ran both ways didn't notice a diff from going to frame. Maybe I didn't know what to look for. Lol
Windwalker
Handle: Windwalker
Real Name: Clifford Stewart
Call Sign: KD8QHS
Antenna: K-40// Hustler MagMnt
Radio: Cherida S890
Re: Battery ground?
#365739
Post by Windwalker »
Well Im sure lots of different folks have different ideas.
The rule for grounds is to make the ground connection tight and clean. Further the ground should be as short as possible.
A long ground running up forward might not help much. Although extra grounds never hurt.
If it works grounding it to the frame then I would use it
JMHO
WW1
Re: Battery ground?
#365742
I feel the same way. I like to keep the ground/negative as short as possible, less length of wire that might pick up noise.
bayou1
Real Name: cliff
Radio: Cobra
Re: Battery ground?
#365757
Post by bayou1 »
I guess the old saying holds true. " if it's not broke don't fix it"
Re: Battery ground?
#365760
I've always ran the ground off the battery bank straight to the frame...Only wire coming from the front, is the hot wire off the front battery to the battery bank.
