How big of a linear can a semi run without creating a proble
night owl
Radio: mud duck radio
Post by night owl » Friday, 17 June 2011, 20:02 PM
I like texas star, and am open to others. I just do not need to create a problem. Power drain or computer problem ect. Linear will be run with proper power cables and fuse.
maters
Re: How big of a linear can a semi run without creating a pr
Post by maters » Sunday, 26 June 2011, 21:15 PM
A sweet 16 connected to a CLEAN radio is fine.
A 29/33/general lee and add your favorite , clipped diodes and peaked will make any electronics suffer.
busdriver389
Radio: rci 2950, 93T,99V
Post by busdriver389 » Thursday, 21 July 2011, 19:31 PM
I ran a 2X8 in mine with no problems. Be careful with texas stars they are amp hogs.
We're all going to die, but I've got a helmet.
352 Smiley
Radio: stryker 447hpc
Antenna: mr.coily comp
Post by 352 Smiley » Tuesday, 23 August 2011, 5:12 AM
i whould use a 1by4 max to play it safe
352 on galveston bay
Post by jessejamesdallas » Tuesday, 23 August 2011, 16:53 PM
Depends on how deep your pockets are, and how well it's installed...I know guys that run 16-24 pill Amps in Big Trucks with no problems, and I know guys that have shut their motors down with 2-pill box's...
Big_Mic
Post by Big_Mic » Sunday, 03 February 2013, 13:32 PM
Currently running a 2x12 with upgraded alternator in a 2012 Freightliner Cascadia at 3,000 watts output... do it all day long... careful antenna installation and choice of coax are 2 areas too concentrate on.... LMR 400 I use for everything... And antenna is mounted off the back behind cab...
Stryker 497HPC/Texas Star Sweet 16/K-40 Coily Antenna's
Yaesu FT 101EE/Alpha (2) 4CX1000's/8 Element beam Flat Side
8 Antenna's in all covering 160-2 Meter
The Pics below give the rest of the story...
RustyFinger
Post by RustyFinger » Saturday, 16 February 2013, 15:03 PM
Big_Mic wrote:Currently running a 2x12 with upgraded alternator in a 2012 Freightliner Cascadia at 3,000 watts output... do it all day long... careful antenna installation and choice of coax are 2 areas too concentrate on.... LMR 400 I use for everything... And antenna is mounted off the back behind cab...
How did you run your coax into yhe cab thank you Rusty
Big_Mic
Post by Big_Mic » Saturday, 16 February 2013, 15:09 PM
Drilled hole behind cab up underneath and brought it on to bunk.. used caulk after running coax to seal around the area where the coax was run through... in all I drilled 4 holes... 1 for the coax and 2 for the #2 positive cable and 1 for the #4 negative cable... The battery cable holes were drilled underneath near the battery box ....
RustyFinger
Post by RustyFinger » Saturday, 16 February 2013, 15:12 PM
So coax just runs down the back of the cab.have aready ran power up in the caab mounted annt on my head acke rack.
Big_Mic
Post by Big_Mic » Saturday, 16 February 2013, 15:16 PM
Yes the coax runs down the cab... looped the coax a bit and used a couple zip ties to keep the coax from pullin g on the connector.
RustyFinger
Post by RustyFinger » Saturday, 16 February 2013, 15:17 PM
Big_Mic wrote:Yes the coax runs down the cab... looped the coax a bit and used a couple zip ties to keep the coax from pullin g on the connector.
how long of coax did you use? Rusty
Big_Mic
Post by Big_Mic » Saturday, 16 February 2013, 15:22 PM
Coax if I remember right was about 20 feet... that got it too the bird.. than 6 feet off of that to the amplifier ... than the jumper between radio and amp was about 9 feet... SWR reflected is about 1/2 percent to 1 percent at a full 3000 watts.
3ZERO8
Radio: Connex 3300hp
Antenna: A99
Cell Phone: 214-797-8642
Post by 3ZERO8 » Saturday, 16 February 2013, 15:25 PM
Dang your swr are that low at 3KW??? What antenna are you running?
-3ZERO8 Texas
-3ZERO8 North Texas
RustyFinger
Post by RustyFinger » Saturday, 16 February 2013, 15:27 PM
Thank you ,for the info.Rusty
Big_Mic
Post by Big_Mic » Saturday, 16 February 2013, 15:29 PM
Running a K40 Coil antenna and yes it is... Mounting it behind the cab and tilting it back slightly toward the trailer increases the feed point impedance giving me a near perfect match... between a combination of tilting the antenna back and trimming it along with good coax... I was able to achieve this.
Sat Feb 16, 2013 5:32 pm
I've also sealed all connections with a clear sealant so I can use it rain or shine without much change due to weatger
Pistol_Pete
Radio: Ranger / RCI 2970N2
Antenna: IMax
Post by Pistol_Pete » Friday, 27 September 2013, 19:15 PM
Out of my liege
Base:
Ranger/RCI 2995 DX / Turner RK 56 / MAX 2000
Mobil 1:
Ranger / RCI 6900F25 / Turner RK 56 / Wilson 1000
Mobil 2:
Ranger/RCI 69FFC2 / Astatic 636L-c / Wilson 1000
Post by MDYoungblood » Saturday, 28 September 2013, 9:17 AM
jessejamesdallas wrote:Depends on how deep your pockets are, and how well it's installed.
This is the best answer on this topic.
Sat Sep 28, 2013 12:21 pm
It actually pertains to any linear install.
again
silvereagle1
Radio: President Lincoln 2
Antenna: Sirio Turbo 5000
Cell Phone: --------------
Post by silvereagle1 » Saturday, 28 September 2013, 13:19 PM
Yep, I've ran across a few of those bugs myself in the past few days. All cleared up now I think but i'm finding out you'll find problems in places you never thought to look.
President Lincoln 2
Sirio Turbo 5000 Roof Mount
567 East Tennessee
