How much difference?
DixieEcho82
Radio: RCI, Galaxy, Uniden
Home Phone: 910-648-6281
Post by DixieEcho82 » Thursday, 28 October 2010, 21:02 PM
If you call and order an amp, say 2 pill for competition keydowns how much difference internally is there? I assume bigger fan, heatsink, etc. but what else?
preacherman
Referrals: 2
Re: How much difference?
Post by preacherman » Friday, 29 October 2010, 6:14 AM
If it is made specifically for keydowns, you may find more capacitance (large caps) on the + rail.
It also is assumed that you will be running higher voltage. If that's not true, there's no advantage.
Now if you go 4 pill or bigger, then there is a difference in average output between amps that
have the pills tuned in fours vs. those tuned in twos. Not higher pep, but higher average. The
higher avg. amp will drop the *Censored* on the other amp. Again...unless you have a competition setup
and an alternator(s) that will provide higher voltage, there isn't much benefit in spending the extra
Preacherman
"Preacherman workin' this mudduck mercury. Topside, Land O' Lincoln"
jerky boy
Radio: Nothin but the best.
Home Phone: 815 398 3552
Post by jerky boy » Sunday, 07 November 2010, 12:24 PM
if you want to be heard in dx then spend the extra money for a well built amp. 222 in ILL .
Image Relay, Relay, Glass User, Pill User.
night owl
Radio: mud duck radio
Post by night owl » Monday, 15 November 2010, 5:41 AM
Sounds like the alternator(s) set up is an extra expense.
dragline
Radio: connex
Post by dragline » Tuesday, 16 November 2010, 18:25 PM
no since in getting a bigger amp than you can supply power to, plus the reserve to operate the vehicle acc or what have you
