Cobra 2000
If you need assistance with a radio modification or have any questions, this forum is the perfect place to ask. Feel free to pop in and join the discussion!
smoke blower
Handle: East coast broadcaster
Real Name: David Sadler
Radio: Cobra 2000
Cobra 2000
#383251
Post by smoke blower »
I have an issue with a cobra 2000 the radio transmits fine but there is no recieve until I key the Mike the recieve comes in for a few seconds then it goes out until I key the Mike then it comes in again.
army1975
Handle: Proud American
Real Name: Keith Goodman
Antenna: Wilson 5000
Radio: Galaxy DX-979
Re: Cobra 2000
#383256
Post by army1975 »
hmmmmmmm............have you tried a different mic? just a thought.
CB Handle: PROUD AMERICAN
smoke blower
Radio: Cobra 2000
Re: Cobra 2000
#383258
Yeah it didn't seem to do any different. I thought it was kind of wierd I don't know if a cap would be causing this or not. I did an alignment on the radio and the receive got a little louder but it went back out until I keyed the mic then the receive come back for a few seconds then went back out.
-- Monday, 13 February 2017, 17:37 PM --
I am not great with reading a schematic so I am not sure if it is a cap which one it would be
army1975
Re: Cobra 2000
#383259
Post by army1975 »
sorry, only thing I could think of. hopefully someone will know what is up with it. good luck.
smoke blower
Radio: Cobra 2000
Re: Cobra 2000
#383260
Thanks man I appreciate it
Deleted User 14541
Re: Cobra 2000
#383261
Post by Deleted User 14541 »
Maybe an old electrolytic that's drying up. I've found issues like this my wetting my finger and tapping around on the solder side of the board. I don't work on radios enough to know the usual suspects.
I there may be 120vac on the board somewhere with the 2000. Be safe and run it on a 12v power supply.
Handle: sonoma
Real Name: sonoma
Radio: President Washington
Re: Cobra 2000
#383263
Post by sonoma »
I would be looking for a bad cap or a cold solder joint. the usual things you should be telling us. is the meter moving as if you are receiving is the rx light changing when you key up. are you actually on freq when it drops out, you could be dropping voltage to the pll or vco area. so many little things can cause this. have you tried hitting parts with some cold spray to see if a part is heating up. do you have the 10.240 freq at the pll. etc etc.
smoke blower
Radio: Cobra 2000
Re: Cobra 2000
#383299
Found the problem it was Vr3 for the squelch was messed up I sprayed it with contact cleaner and moved it back and forth and everything is working fine now. I had no idea this would cause it to do this.
Deleted User 14541
Re: Cobra 2000
#383300
Good find. I had dirty pot that kept screwing up the bias adjustment on an almost new TX Ranger 296. Sprayed it and no more issues.
army1975
Re: Cobra 2000
#383302
Post by army1975 »
alrighty then, done gone and learnt something new. now if happens to someone else, you will able to help them out. :cheers:
smoke blower
Radio: Cobra 2000
Re: Cobra 2000
#383316
Thanks guys yeah I wish I had more time to get on here and help but I am busy this time of year on the gas truck. Between stops I go on my phone and check out the post and reply when I can.
