500W 3 Pill Fatboy
RedMan CB Radio Stop has all your CB and 10 meter Radio Supplies at Great Prices. New base and mobile radios Galaxy, RCI ,Connex, Superstar Uniden.
Moderators: Barracuda, JR Moderator
DarkEyes
Radio: Magnum S9 + 4 Pill
Antenna: MM9 18" Shaft
500W 3 Pill Fatboy
Post by DarkEyes » Wednesday, 10 June 2009, 2:07 AM
Was looking at this..
500 Watt 3 pill 2290 driver Amp Fan and Remote Jack
1x2290 dr 2x2879 Low drive 2-4 watts deadkey 50 amp power Supply will run this amp
variable power control
Does that mean I cant just run it to my battery? Do i need a power supply to run it?
Sorry I am new to amp.
Thanks
linx
Radio: 2 tin cans + string
Referrals: 6
Re: 500W 3 Pill Fatboy
Post by linx » Wednesday, 10 June 2009, 4:31 AM
No, it just means it's small enough to run on a 50 amp power supply in your house. The leads coming off the power supply are 12 volts, which is the same as your car.
In other words, you can run it off your car battery just fine. Some people just look for amps that will run off a power supply of 50 amps in your house, b/c if you get a power supply bigger than that, it's a large investment.
VOTE FOR CBRT TODAY!
CBRT ON TWITTER!!!
My Twitter Too
KW KID
Radio: YAESU 101EE
Post by KW KID » Wednesday, 10 June 2009, 14:50 PM
50 amps should be fine. Power supplies have a wattage rating as well. A 50 amp power supply may support 13.8 x 50 = 690 watts. 500 watts is peak watts or "happy watts". The real power a 2 pill does is around 200-250 watts RMS, and the current/power draw will reflect that minus it's efficiency.
Red Warrior
Radio: Galaxy 959
Post by Red Warrior » Wednesday, 10 June 2009, 15:08 PM
RF Parts data sheets has the following info:
SD1446 90W output with 5W input
2SC2290 80W output with 4W input
2SC2879 120W output with 7W input
Ratings are at 30MHz, 12.5-13.6v
Figure about 60% efficiency.
DarkEyes
Post by DarkEyes » Wednesday, 10 June 2009, 21:49 PM
Thanks for the info everyone...
DarkEyes
Post by DarkEyes » Thursday, 11 June 2009, 1:30 AM
What wire guage would i need to run that amp? I know bigger is better but running 2guage from the battery to the trunk would be a pain.
SlingShot
Radio: 148fgtl dx+/TS667V
Post by SlingShot » Thursday, 11 June 2009, 3:17 AM
4 gauge would be good.
