antenna tuning
Mr_Grinder
Real Name: Phil
antenna tuning
Post by Mr_Grinder »
I'm thinking of putting a antenna on the house . My question is do you have to set the swr in the mounted position ? And to change it if necessary do you have to keep taking it down ? Or can you set it while on the ground instead of the roof ?
Handle: sonoma
Real Name: sonoma
Radio: President Washington
Re: antenna tuning
Post by sonoma »
I put the antenna on a short pole about 6 foot off the ground and set the swr. that has worked for me. this way it is low enough to set the swr off a ladder.
Re: antenna tuning
On most base antennas the SWR will be close just by following the instructions. Like sonoma I generally built the antenna on the ground, double checked the measurements and SWR a few times before installing it. You didn't say what antenna you want to install, with that info we can give you a better answer.
Re: antenna tuning
yep. tune on a short 8-10' pole, then it should be pretty close to the same once up...Dual polarity antenna's are a bit tricky to tune on the ground, can be done by just rotating the antenna's boom to tune the horizontal elements.
Mr_Grinder
Real Name: Phil
Re: antenna tuning
thank you all for your response's . i'm thinking ether a Solarcon MAX 2000 or a
Hy-Gain SPT-500 Super Penetrator . but you eased my worry's a great deal . i'm a big fan of easy and think i'll be able to handle this project . thanks again ...
