RF Bonding
Dirge
Radio: Galaxy 959
Antenna: Wilson 5000
RF Bonding
Post by Dirge » Thursday, 24 September 2015, 10:51 AM
I want to start rf grounding my unibody mobile. I'm waiting on some 1 inch braided copper to arrive.
Plans are:
2 straps on the hood
2 straps on the trunk
1 strap for each door
3 straps on the exhaust system
2 straps for each bumper
I've read where some guys go even further and throw straps on the engine, tranny, radiator, and suspension parts. Is that overkill or worthwhile?
Re: RF Bonding
Post by MDYoungblood » Thursday, 24 September 2015, 13:41 PM
Hello Dirge,
Welcome back. What you have listed sounds good to me, really only need one on the exhaust behind the converter, the engine ground will take care of anything before it. The hood and trunk you can use two along with one on each door. I've added a strap to my engine, I did that to help with any noise it may produce, the transmission is bolted to it so that isn't needed but wouldn't hurt. Never did the radiator or suspension, those parts are shielded by the hood and body. What make vehicle are you working on?
Dirge
Radio: Galaxy 959
Re: RF Bonding
Post by Dirge » Thursday, 24 September 2015, 15:59 PM
Nissan Sentra. The windshield wipers are the noisiest part of the car.
Lost Ram
Radio: Yaesu FT-991
Antenna: 700' Loop
Re: RF Bonding
Post by Lost Ram » Thursday, 24 September 2015, 19:03 PM
Hello,
Be sure to remove the paint where you bolt/mount these connections. Normally a can of matching spray paint can be had at the auto parts store and applied when you are done if wanted.
CB: TRC-450, Imax@50'
Ham : Yaesu FT-857D, FT-897D, FT-990 and FT-991, FT-8900
Ham Antennas: 700' and 258' wire loop, Maco shooting Star tuned for 10 Meter, 250' doublet, 8E 2M Quad-SSB, 4E 2M Quad-FM, 2M Copper Slim Jim 2M omni.
Thomas Jefferson.
Re: RF Bonding
Post by MDYoungblood » Friday, 25 September 2015, 6:18 AM
I use internal star lock washers instead of grinding off the paint, the teeth on them dig into the metal through the paint and a dab of dielectric grease keeps the area from rusting. For the wiper motor you could try a couple of disc capacitors across the leads to clean up the noise.
Dirge
Radio: Galaxy 959
Re: RF Bonding
Post by Dirge » Friday, 25 September 2015, 12:31 PM
I've read that some newer cars have plastic or fiberglass radiator mounts. My car doesn't but the continuity tester says it is floating, so maybe the paint is blocking the electron flow. Turns out the hood, front fenders, and trunk are also floating. However, the doors are checking okay (but strapping them would be better).
Re: RF Bonding
Post by MDYoungblood » Friday, 25 September 2015, 13:19 PM
Check the hood and trunk lid with a magnet to make sure it's metal, Nissan used a lot of carbon fiber/fiberglass parts on their bodies. If they are non metal a single small ground strap would help bleed off any static buildup on the surface of the material. The hood and trunk hinges used a plastic bushing which will isolate it from ground, even the hood/trunk locks use plastic bushings and the trunk has a rubber seal.
Dirge
Radio: Galaxy 959
Re: RF Bonding
Post by Dirge » Sunday, 27 September 2015, 8:55 AM
MDYoungblood wrote: ...and a dab of dielectric grease keeps the area from rusting.
I assume the dielectric grease goes on top of the finished connection and not in between the parts.
bluemeanie
Radio: LOTS OF TUBES
Antenna: Max 2000 MACO M105
Home Phone: 9706253581
Cell Phone: 9709489991
Re: RF Bonding
Post by bluemeanie » Sunday, 27 September 2015, 10:10 AM
Also a little dab of RTV of the color of your choice works too.
Re: RF Bonding
Post by MDYoungblood » Sunday, 27 September 2015, 11:10 AM
I put a dab between the washer and paint, washer and bolt, it will not interfere with making good contact. You can do like blue said, just check to make sure it's non corrosive silicone.
Dirge
Radio: Galaxy 959
Re: RF Bonding
Post by Dirge » Sunday, 27 September 2015, 15:29 PM
Well, I got the hood, front fenders, and trunk done. Don't know if it helps the CB but the key fob works a lot farther away!
543FtWorth
Radio: (non-sponsor) 29 LTD
Antenna: *Censored*
Re: RF Bonding
Post by 543FtWorth » Sunday, 27 September 2015, 15:46 PM
Dirge wrote:Well, I got the hood, front fenders, and trunk done. Don't know if it helps the CB but the key fob works a lot farther away!
:lol: Looks like you killed two birds with one stone. :lol:
Re: RF Bonding
Post by MDYoungblood » Tuesday, 29 September 2015, 13:43 PM
Now that is interesting, might have to try it on my Jeep because the "fob" doesn't work well at all on it.
southwind
Antenna: Shakespeare BigStick
Re: RF Bonding
Post by southwind » Tuesday, 29 September 2015, 14:18 PM
:bounce: Your radiator is probably floating in metal brackets ( 2 upper/2 lower ) with rubber grommets for insulation. Strange about the key FOB, you always learn something on this site. Good luck.......... :cheers:
David g.
AKA Tripple Nickel, DX 555. Base station-Uniden Washington, Philippines made, D-104 Tug 8 , Silver Eagle 200/Pyramid Gold Series Variable 26 amp, through "Old Reliable Shakespeare BigStick"... Mobile-148gtl, Cobra 25, NMO firestik.
USAF 1959-1963/ John F. Kennedy Innaguration parade 1961.
Image Image
