Massive 3/8 mount for Predator 10k
Foliant
Antenna: K40 SF300
Post by Foliant » Wednesday, 25 March 2015, 6:36 AM
How does a massive 3/8 mount for a Predator 10k look and where can i get one?
I have this one,
but I need a mount where the antenne will press against the whole mount.
Regards
Patrick
de 13PR87
1206FL
Re: Massive 3/8 mount for Predator 10k
Post by 1206FL » Wednesday, 25 March 2015, 7:01 AM
**NON-SPONSOR** mounts
Sent from my iPhone using Tapatalk
Post by jessejamesdallas » Wednesday, 25 March 2015, 8:52 AM
Clays CB Radio should have the official Predator 10K stud mounts in stock...You can also check Predator 10K Discount Antennas.
Foliant
Antenna: K40 SF300
Post by Foliant » Wednesday, 25 March 2015, 9:36 AM
Ok, what is a "Lug Mount" and how are they used?
I cant see a cap or some other shielding for the part inside the car.
If i simply strip the koax an put the inner conductor on the mount there will happen funny things with my board electronics.
de 13PR87
Post by MDYoungblood » Wednesday, 25 March 2015, 11:49 AM
For those heavy weight antennas you need to be looking at "puck" mounts, they are designed to handle the load and support the sheet metal from bending.
Foliant
Antenna: K40 SF300
Post by Foliant » Wednesday, 25 March 2015, 14:09 PM
For my 17" shaft Predator wants a
H/D stabilizer stud with terminals. Designed for Predator and similar large coil type antennas. Recommended for 17 inch and longer shaft antennas. Requires terminal type coax cable.
But I dont know what a terminal type coax is. What i can guess from the pics is that it must be some sort of cable lug - but there my misgiving beginns: Where is the shielding?!
I think the Model #076 from breedlovemounts might be all i need (its 1 inch in diameter where the Antenne is about 0,9inch) but shipping is $45 where the Puck costs $40...
de 13PR87
Post by MDYoungblood » Wednesday, 25 March 2015, 15:32 PM
Terminal type coax,
The center conductor goes to the stud bolt, shield to a close ground bolt but you knew that.
Foliant
Antenna: K40 SF300
Post by Foliant » Wednesday, 25 March 2015, 17:46 PM
Shockingly, its what i was expecting but now im sure that this is really not a 50Ω connection.
I was trying somewhat similar times ago, sticking the center with a 4mm Jack to a pipe type connector and bonded the twistet shield to the threading.
I had to borrow a Computer, the Adapter and the right Software to flash my car electronics... I will never do any unshielded connection anymore.
Now i know enough about the diferent mounts, only my wallet is against the only right way... :confused:
de 13PR87
1206FL
Post by 1206FL » Friday, 27 March 2015, 4:14 AM
A good mount won't be cheap. Check out where JJD is telling you. He knows those a lot about those antennas. A good plate on the underside of the vehicle also will help with support. You gotta pay to play lol. It's not a cheap hobby if you want to do it right. Don't skimp out on antenna system. That is for sure!!
Foliant
Antenna: K40 SF300
Post by Foliant » Saturday, 28 March 2015, 8:33 AM
After i have talked to someone who has imported genuine Predator mounts in the past just to dump them i will get a **NON-SPONSOR**.
You tell it "Get what you pay for."
de 13PR87
