Need some advice
alfred56
Handle: 581
Real Name: Andrew
Antenna: sirio p5000
Radio: galaxy 98 vhp
Need some advice
#359035
Post by alfred56 »
Ok guys I am pulling hair out trying to figure this one out . I have real bad ignition noise on the mobile. I have bonded just about every thing I can think off. It has gotten better but makes radio almost unusable still. Any ideas I am willing to try anything right now. If you need some more info let me know
Sent from my DROID RAZR using Tapatalk
dirtyjob
Handle: dirtyjob
Real Name: Mark
Antenna: Super Penetrator 500
Radio: Many
Re: Need some advice
#359036
Post by dirtyjob »
have you tried grounding the exhaust
"LISTEN FOR THE PING"
Gizmotchy G-31 Beam
Super Penetrator 500 5/8 Wave
Comet GP9 2 meter/440
CBRT 18204
silvereagle1
Handle: Silver Eagle
Real Name: Mark
Antenna: Sirio Turbo 5000
Radio: President Lincoln 2
#359037
Post by silvereagle1 »
I've always heard grounding the exhaust helps but why the exhaust and is it not grounded already? I may try it myself.
President Lincoln 2
Sirio Turbo 5000 Roof Mount
567 East Tennessee
alfred56
Handle: 581
Real Name: Andrew
#359038
Post by alfred56 »
Yes in one spot also the heads to frame with one inch strap l am going to put one or treetop more on exhaust more
721HACKSAW
#359039
Post by 721HACKSAW »
You describe it as ignition noise... I wonder if it could be alternator or fuel pump instead. We need to try an isolate the source of the noise first. The noise goes away when the vehicle isn't running, correct?
For me it was the fuel pump, a small capacitor across the fuel pump cured most of the noise. A ground strap on the exhaust pipe also helped slightly.
alfred56
Handle: 581
Real Name: Andrew
#359041
Post by alfred56 »
I know it is ignition when I disconnect msd noise is gone alt case is grounded and have can driven fuel pump
#359043
Well you found your own problem, high performance ignition systems and radios don't mix. I would contact MSD Ignition, http://www.msdignition.com/ , and ask what can be done to eliminate or at least reduce the spark chatter. I am guessing that you are running resistor plugs and new suppression wires.
alfred56
Handle: 581
Real Name: Andrew
#359054
Post by alfred56 »
Yes I am I contacted them first and of no help. All they could suggest was a capacitor they sell witch I have so I guys its time to take msd out
#359056
Don't give up yet. When you disconnect the antenna (leave the MSD unit hooked up), do you still hear the ignition noise in the radio?
alfred56
Handle: 581
Real Name: Andrew
#359057
Post by alfred56 »
Will check after work
#359058
Okay, we can give some advise then. Just a couple questions,
How is the radio wired?
Antenna location? Did you check/adjust the SWR? How is the radio mounted?
alfred56
Handle: 581
Real Name: Andrew
#359061
Post by alfred56 »
Antenna is dead center on roof hard mounted sirio 5000 wired direct too batt on positive and negative yo seat bolt radio is in a home made pedestal ABCs has strap to floor and have a 1.3:1 swr and the noise its not there when I disconnect the coax
#359064
Okay, so it is the MSD unit since you said it doesn't do it when unhooked. First thing to try would be to ground (bond) the MSD box, it has a positive and negative lead but the negative just is for the circuitry in the unit and not a ground for the box itself. You said you used the cap that MSD recommended, that will do little to help. There is also the possibility that the unit is bad. Next it could be a bad rotor in the distributor, too much gap to the contacts, arching inside the distributor cap. It could be happening when using the MSD, but not with the stock system, take the cap off and check it, wash out any debris with water, give it a light spray of WD40 and wipe or blow it dry, a dab of dielectric grease on the center contact. We know it's not the wires and the plugs if it doesn't happen when unhooked.
alfred56
Handle: 581
Real Name: Andrew
#359068
Post by alfred56 »
Thanks Greg I will check the rotor and cap but I bonded the box today no better finish to throw another strap on the exhaust tomorrow and see if it is better
