Mobile install suggestions
- BigRed2294
- Handle: Big Red
- Real Name: Alex Faulkner
- Antenna: Wilson Little Wil
- Radio: Cobra 29 LTD Classic
I need some suggestions on a small radio to install in my blazer in the place of the tape player. I already have a cobra 29 and galaxy 949 but i need something smaller. the opening is 2 inches high by 6 inches wide. any suggestions will help. thanks.
Re: Mobile install suggestions
Nothing wrong with the compact CB's out there on the market. I'm a fan of the Uniden Pro510xl and Pro520xl myself. I have a couple of the 510's...one I bought back in '94 and it still works great to this day. They are a hard value to beat at just over $40 brand new. Heck, they have darn near 100% audio right out of the box. Not sure if that's the info' you were after or not?
Good luck
231
Good luck
231
- BigRed2294
- Handle: Big Red
If you dont mind could you measure the face of the 510 for me? All the measurements online are of the top of it.231 wrote:Nothing wrong with the compact CB's out there on the market. I'm a fan of the Uniden Pro510xl and Pro520xl myself. I have a couple of the 510's...one I bought back in '94 and it still works great to this day. They are a hard value to beat at just over $40 brand new. Heck, they have darn near 100% audio right out of the box. Not sure if that's the info' you were after or not?
Good luck
231
- jessejamesdallas
The New Uniden 680 is not a bad radio...It's (L x W x H): 6.25 x 6.2 x 2.4...
I installed one of these one time in the dash of my Toyota Tacoma in-place of where the little cubby-hole tray thing was at under the stereo.
- BigRed2294
- Handle: Big Red
That wont fit in the space i have thoughjessejamesdallas wrote:The New Uniden 680 is not a bad radio...It's (L x W x H): 6.25 x 6.2 x 2.4...
Can you make that "space I have" larger? Most of the exterior moldings in newer cars are plastic and can be replaced.
- sonoma
- Handle: sonoma
- Real Name: sonoma
- Radio: President Washington
the 510xl is 2 in high, 7 in deep and 5 in wide.
- jessejamesdallas
That's what drills, jig-saw's, and dremel tools are made for!BigRed2294 wrote:That wont fit in the space i have thoughjessejamesdallas wrote:The New Uniden 680 is not a bad radio...It's (L x W x H): 6.25 x 6.2 x 2.4...
"If it won't fit...Make it fit!"
- Grinder74
- Handle: Grinder
- Real Name: Chris
- Call Sign: KE8EOJ
- Antenna: 102"GP, 2M Yagi
- Radio: Kenwood TR-751a, Yaesu FT8800, President HR2510, Uniden TRC-465, Teaberry "T" 40ch
Yes the Dremel4000 is I believe the best tool I have ever bought, the flex shaft lets you get into some tight areas the cut. That whole pocket area in your Blazer could be cut out to fit a 7" wide radio there and have enough plastic left to give it that custom install look.
- BigRed2294
- Handle: Big Red
Do you think i could get a cobra 25 to fit in there?
February 27th, 2014, 10:01 pm
just about any dremel is a good tool. i dont know which one mine is but its older. i use more then any other tool i own. lolMDYoungblood wrote:Yes the Dremel4000 is I believe the best tool I have ever bought, the flex shaft lets you get into some tight areas the cut. That whole pocket area in your Blazer could be cut out to fit a 7" wide radio there and have enough plastic left to give it that custom install look.
A Cobra 25 LTD or GTL is about 6 & 1/4 inches wide, I believe there is enough plastic on the sides to remove and get it to fit quite snugly.
If you have a local auto recycler, see if you piece you need to cut and save the original for when you sell the Blazer.
