Mobile install suggestions
BigRed2294
Handle: Big Red
Real Name: Alex Faulkner
Antenna: Wilson Little Wil
Radio: Cobra 29 LTD Classic
Post by BigRed2294 »
I need some suggestions on a small radio to install in my blazer in the place of the tape player. I already have a cobra 29 and galaxy 949 but i need something smaller. the opening is 2 inches high by 6 inches wide. any suggestions will help. thanks.
231
Re: Mobile install suggestions
Post by 231 »
Nothing wrong with the compact CB's out there on the market. I'm a fan of the Uniden Pro510xl and Pro520xl myself. I have a couple of the 510's...one I bought back in '94 and it still works great to this day. They are a hard value to beat at just over $40 brand new. Heck, they have darn near 100% audio right out of the box. Not sure if that's the info' you were after or not?
Good luck
231
BigRed2294
Handle: Big Red
231 wrote:Nothing wrong with the compact CB's out there on the market. I'm a fan of the Uniden Pro510xl and Pro520xl myself. I have a couple of the 510's...one I bought back in '94 and it still works great to this day. They are a hard value to beat at just over $40 brand new. Heck, they have darn near 100% audio right out of the box. Not sure if that's the info' you were after or not?
Good luck
231
If you dont mind could you measure the face of the 510 for me? All the measurements online are of the top of it.
The New Uniden 680 is not a bad radio...It's (L x W x H): 6.25 x 6.2 x 2.4...
I installed one of these one time in the dash of my Toyota Tacoma in-place of where the little cubby-hole tray thing was at under the stereo.
BigRed2294
Handle: Big Red
jessejamesdallas wrote:The New Uniden 680 is not a bad radio...It's (L x W x H): 6.25 x 6.2 x 2.4...
That wont fit in the space i have though
Can you make that "space I have" larger? Most of the exterior moldings in newer cars are plastic and can be replaced.
Handle: sonoma
Real Name: sonoma
Radio: President Washington
Post by sonoma »
the 510xl is 2 in high, 7 in deep and 5 in wide.
That's what drills, jig-saw's, and dremel tools are made for!
"If it won't fit...Make it fit!" :mrgreen:
Grinder74
Handle: Grinder
Real Name: Chris
Call Sign: KE8EOJ
Antenna: 102"GP, 2M Yagi
Radio: Kenwood TR-751a, Yaesu FT8800, President HR2510, Uniden TRC-465, Teaberry "T" 40ch
Post by Grinder74 »
You forgot sawzall
KE8EOJ
Yes the Dremel4000 is I believe the best tool I have ever bought, the flex shaft lets you get into some tight areas the cut. That whole pocket area in your Blazer could be cut out to fit a 7" wide radio there and have enough plastic left to give it that custom install look.
BigRed2294
Handle: Big Red
Do you think i could get a cobra 25 to fit in there?
February 27th, 2014, 10:01 pm
MDYoungblood wrote:Yes the Dremel4000 is I believe the best tool I have ever bought, the flex shaft lets you get into some tight areas the cut. That whole pocket area in your Blazer could be cut out to fit a 7" wide radio there and have enough plastic left to give it that custom install look.
just about any dremel is a good tool. i dont know which one mine is but its older. i use more then any other tool i own. lol
A Cobra 25 LTD or GTL is about 6 & 1/4 inches wide, I believe there is enough plastic on the sides to remove and get it to fit quite snugly.
If you have a local auto recycler, see if you piece you need to cut and save the original for when you sell the Blazer.
