2001 jeep grandcherokee install
Radio: magnums9 /madison
Antenna: 102 whip
Cell Phone: 4012062673
Post by p38 » Sunday, 20 October 2013, 15:53 PM
well after the blazer died i bought a jeep its pristine clean and has been taken care of. cant find a spot too mount my delta force im liking the dash a bit but id like too see where others have theirs mounted. ill be puting the 102 whip on this one as well with the quick disconnect so i can open the hatch thoughts comments and concerns? oh and power will be direct too battery with a fuse just after power leaves the battery and a 250watt noise filter under the passenger dash.
Friday, 25 October 2013, 20:12 PM
well ive another question maybe a few gents out there might know how many amps i should feed this rig? the radio itself pulls 5 but i was tld this has an internal noise filter? what do those usually pull 10 amps? i've yet too pull the cover off it too check it out
Friday, 25 October 2013, 20:22 PM
ASE certified technician
