new base set up
FreeBallin
new base set up
Post by FreeBallin » Saturday, 27 July 2013, 9:48 AM
hello everyone, new to the radio after around 20 years. i have a Uniden 980ssb i would like you use as a mobile and base set up,, will this power supply and AMP be sufficient enuf for this set up? ,,,,,,,,,Pyramid PS15KX 10A 13.8-Volt Power Supply and this AMP............RM Italy KL 203P HF Linear Amplifier, thanks in advance for any ones help!!
Re: new base set up
Post by 'Doc » Saturday, 27 July 2013, 18:53 PM
What size fuse in the radio? What size fuse for the amplifier? Add the two together and if the total is less than about half, or maybe two-thirds the output of that power supply, the power supply should be large enough. Considering how power supplies are commonly advertised, having one rated for twice the anticipated current draw would be better.
Re: new base set up
Post by MDYoungblood » Saturday, 27 July 2013, 22:21 PM
Hello FreeBallin,
The power supply will work fine for the Uniden 980SSB but is a little small for the RM Italy 203P, minimum for the amp is around 14A. So you will need to get a power supply that will do that and it needs to be continuous amperage. It would be better to run them separately anyway.
FreeBallin
Re: new base set up
Post by FreeBallin » Sunday, 28 July 2013, 2:58 AM
Thanks for the help guys!...
