The New Dx Directory
COMING SOON!
Title 95.667 CB transmitter power.
Phaze91460
Post by Phaze91460 » Sunday, 07 January 2007, 13:24 PM
Code: Select all
[Title 47, Volume 5]
[CITE: 47CFR95.667]
[Page 548]
                       TITLE 47--TELECOMMUNICATION
                         COMMISSION (CONTINUED)
                     Subpart E_Technical Regulations
Sec. 95.667  CB transmitter power.
    The dissipation rating of all the semiconductors or electron tubes
which supply RF power to the antenna terminals of each CB transmitter
must not exceed 10 W. For semiconductors, the dissipation rating is the
greater of the collector or device dissipation value established by the
manufacturer of the semiconductor. These values may be temperature de-
rated by no more than 50 [deg]C. For an electron tube, the dissipation
rating is the Intermittent Commercial and Amateur Service plate
dissipation value established by the manufacturer of the electron tube.
[53 FR 36789, Sept. 22, 1988. Redesignated at 61 FR 28769, June 6, 1996,
and further redesignated at 61 FR 46567, Sept. 4, 1996]
