The New Dx Directory
COMING SOON!
Title 95.625 CB transmitter channel frequencies.
Phaze91460
Post by Phaze91460 » Sunday, 07 January 2007, 13:23 PM
Code: Select all
[Title 47, Volume 5]
[CITE: 47CFR95.625]
[Page 536-537]
                       TITLE 47--TELECOMMUNICATION
                         COMMISSION (CONTINUED)
                     Subpart E_Technical Regulations
Sec. 95.625  CB transmitter channel frequencies.
    (a) The CB transmitter channel frequencies are:
                          Channel No.                             (MHz)
1..............................................................   26.965
2..............................................................   26.975
3..............................................................   26.985
4..............................................................   27.005
5..............................................................   27.015
6..............................................................   27.025
7..............................................................   27.035
8..............................................................   27.055
9..............................................................   27.065
10.............................................................   27.075
11.............................................................   27.085
12.............................................................   27.105
13.............................................................   27.115
14.............................................................   27.125
[[Page 537]]
15.............................................................   27.135
16.............................................................   27.155
17.............................................................   27.165
18.............................................................   27.175
19.............................................................   27.185
20.............................................................   27.205
21.............................................................   27.215
22.............................................................   27.225
23.............................................................   27.255
24.............................................................   27.235
25.............................................................   27.245
26.............................................................   27.265
27.............................................................   27.275
28.............................................................   27.285
29.............................................................   27.295
30.............................................................   27.305
31.............................................................   27.315
32.............................................................   27.325
33.............................................................   27.335
34.............................................................   27.345
35.............................................................   27.355
36.............................................................   27.365
37.............................................................   27.375
38.............................................................   27.385
39.............................................................   27.395
40.............................................................   27.405
    (b) Each CB transmitter must be maintained within a frequency
tolerance of 0.005%.
