Title 95.607 CB transmitter modification.
This is a place to read about the rules and regulations set down by the Federal Communications Commission (FCC) regarding CB Radio.
Phaze91460
Post by Phaze91460 » Sunday, 07 January 2007, 13:22 PM
Code: Select all
[Title 47, Volume 5]
[CITE: 47CFR95.607]
[Page 535]
                       TITLE 47--TELECOMMUNICATION
                         COMMISSION (CONTINUED)
                     Subpart E_Technical Regulations
Sec. 95.607  CB transmitter modification.
    Only the holder of the grant of authorization of the particular
certificated CB transmitter may make the modifications permitted under
the provisions for certification (see part 2 of this chapter.) No
grantee shall make any of the following modifications to the transmitter
without prior written permission from the FCC (Federal Communications
Commission):
    (a) The addition of any accessory or device not specified in the
application for certification and authorized by the FCC in granting the
certification;
    (b) The addition of any switch, control or external connection;
    (c) Any modification to provide for additional transmitting
frequencies, increased modulation level, a different form of modulation,
or increased TP (RF transmitter power expressed in W (watts), either
mean power (TP averaged over at least 30 cycles of the lowest modulating
frequency, typically 0.1 seconds at maximum power) or peak envelope
power (TP averaged during 1 RF cycle at the highest crest of the
modulation envelope), as measured at the transmitter output antenna
terminals.)
[53 FR 36789, Sept. 22, 1988, as amended at 63 FR 36610, July 7, 1998]
                           Technical Standards
