Title 95.408 How high may I put my antenna?
Phaze91460
Post by Phaze91460 » Sunday, 07 January 2007, 12:55 PM
Code: Select all
[Title 47, Volume 5]
[CITE: 47CFR95.408]
[Page 529-530]
                       TITLE 47--TELECOMMUNICATION
                         COMMISSION (CONTINUED)
               Subpart D_Citizens Band (CB) Radio Service
Sec. 95.408  (CB Rule 8) How high may I put my antenna?
    (a) Antenna means the radiating system (for transmitting, receiving
or both) and the structure holding it up (tower, pole or mast). It also
means everything else attached to the radiating system and the
structure.
    (b) If your antenna is mounted on a hand-held portable unit, none of
the following limitations apply.
    (c) If your antenna is installed at a fixed location, it (whether
receiving, transmitting or both) must comply with either one of the
following:
    (1) The highest point must not be more than 6.10 meters (20 feet)
higher than the highest point of the building or tree on which it is
mounted; or
[[Page 530]]
    (2) The highest point must not be more than 18.3 meters (60 feet)
above the ground.
    (d) If your CB station is located near an airport, and if you
antenna structure is more than 6.1 meters (20 feet) high, you may have
to obey additional restrictions. The highest point of your antenna must
not exceed one meter above the airport elevation for every hundred
meters of distance from the nearest point of the nearest airport runway.
Differences in ground elevation between your antenna and the airport
runway may complicate this formula. If your CB station is near an
airport, you may contact the nearest FCC field office for a worksheet to
help you figure the maximum allowable height of your antenna. Consult
part 17 of the FCC's Rules for more information.
    Warning: Installation and removal of CB station antennas near
powerlines is dangerous. For your safety, follow the installation
directions included with your antenna.
[48 FR 24894, June 3, 1983, as amended at 48 FR 41416, Sept. 15, 1983]
