General Hp 40
- starscream
- Handle: arrow
- Real Name: Gary
- Antenna: Wilson 5000
- Radio: General Lee
General Hp 40
I'm thinking on getting one to use for a base station... i got the power supply so i'm good there what are the pros and cons
- JetSetter
- Moderator
- Handle: JetSetter/822
- Real Name: Greg
- Antenna: 11m Dipole, PAT-12, Browning BR-28
- Radio: RCI-2995DXCF
Re: General Hp 40
I've been keeping my eye on that one also. Very nice radio http://www.gijoesradioelectro ... oduct=1334
Check out some of Bozos video gates, as that's the rig he uses.
"822" Were Alive and Kickin'
From the land of Lincoln
Re: General Hp 40
I think it is one of the better modulating "AM/FM radios" on the market, they are getting a little hard to find. It is a "conversion" radio so it needs to be modded for 11m which adds to the price. The receive is the same as any other model. You said you have a PS, how big is it?
- starscream
- Handle: arrow
- Real Name: Gary
Re: General Hp 40
12Amp
Re: General Hp 40
That isn't big enough, bare minimum for that radio is at least a 30A supply. When a supply is rated they use the peak output reading, the continuous output is always less.
- JetSetter
- Moderator
- Real Name: Greg
Re: General Hp 40
Sounds like someone needs a Megawatt S400
- starscream
- Handle: arrow
- Real Name: Gary
Re: General Hp 40
on my pyramid input 115V ac 60 Hz 250 W
output 13.8 V dc
10 amp constant 12 amp surge
output 13.8 V dc
- JetSetter
- Moderator
- Real Name: Greg
Re: General Hp 40
Like MD said, you need something with at least 30 amp. I myself use the Megawatt S-350 for my 2 radios, and will be buying another one to run my amp. The supply you have is fine for a radio. Check out the site, and mention your a member here http://www.megawattpowersupplies.com/
