Predator 10K on a Stainless Steel Marine antenna mount.
Here is a great place to start your learning process, or for you experts to give advise.
SmallTruckBigRadio
Radio: SWP / SR RCI 2950dx
Post by SmallTruckBigRadio » Saturday, 18 November 2006, 19:39 PM
The hinge is a standard stainless steel marine VHF antenna mount ($35, West Marine, A2O in Clarksville, IN)with a 24" extension pipe ($25). I can elaborate if needed. I'm a little short on time right now.
At the top of the extension pipe, I cut off the threaded part (about 1").
I drilled and tapped, eight 10-32 stainless steel setscrews (Home Depot) to hold the PL-259 connector.
The tricky part is that you have to fish the Mini-8 coax through the pipe, then solder the end on.
I used the Predator PL-259 base ($20).
I damaged my first PL-259 connector by putting the setscrews too tight, and I crushed the predator inner insulator by screwing it too tight at first.
I used a large hole saw to get through the bed liner. I buffed off the paint where the hinge mounted. I used SS sheet metal screws to mount the hinge.
I put c-o-pper paste (never-seize) between the hinge and the bed to prevent rust and help with a good ground. I used the c-o-pper paste at all ground connections.
I used 1" c-o-pper braided tubing (~$1-$2 / ft) for the grounding. I used a hose clamp to land the c-o-pper braid to the extension pipe. the c-o-pper braid is smashed between the hinge and bed, and continues to the frame, and cab. I used #8 TEK screws and c-o-pper paste to land the grounds underneath.
The pipe makes the antenna tune a little long, so a little extra cutting of the whip is needed. The Wilson 2000 works well on it too. The long tune situation kept me from being able to use an Everhardt Tiger SOTT-5 antenna because it wouldn't tune short enough.
Last edited by SmallTruckBigRadio on Monday, 20 November 2006, 20:49 PM, edited 1 time in total.
CB report card:
SWP SR RCI2950dx +TB +echo(A++)
SWP SR General Lee(A+) VarTB +10 pts
I've tried Galaxy 4 times (regretted every one)
DAVEMADE 3pill(A+) solid
FATBOY 3pill(A) almost a DaveMade
RK 56(A+) full sound, cords fail allot
Astatic 636L(A) best value, hold it against DaveMade!
Astatic D104M6(A) tinny, not noise cancelling
Shure 577b(A) only if you have a very hot radio, very low audio
SkyThumper ST-65DX(B) high energy, but junky sounding
Users browsing this forum: No registered users and 4 guests
