Straight 6 Pill Amp Schematics - With Pictures
Here is a great place to start your learning process, or for you experts to give advise.
WESTGATE
Post by WESTGATE » Monday, 16 November 2009, 3:41 AM
continued in straight 6 schematics "part2"
WESTGATE
WESTGATE
straight 6 pill schematics "part 2"
Post by WESTGATE » Monday, 16 November 2009, 3:55 AM
continued in straight 6 pill"part3"
WESTGATE
WESTGATE
straight 6 pill schematics "part 3"
Post by WESTGATE » Monday, 16 November 2009, 4:06 AM
parts list
R1, R2, R3, R4, R5,
& R6 10Ω 1/2W Carbon Film Resistor 6 Brown-Black-Black
R7, R8, R9, R10,
R11, R12, R13, R14,
R15, R16, R17,
& R18 100Ω 2W Carbon Film Resistor 12 Brown- Black- Brown
R19 4.7Ω 2W Carbon Film Resistor 1 Yellow-Violet-Gold
C1, C2, & C3 180 pf Silver Dipped Mica Capacitor 3 180 or 181 / 500V
C4, C5, & C6 330pf Silver Dipped Mica Capacitor 3 330 or 331 / 500V
C7, C8, & C9 1000pf Metal Clad Capacitor 3 1000
C10, C11, C12, C13,
C14, & C15 .01uf Ceramic Disc Capacitor 6 103 or .01
C16, C17, C18, C19
C20, & C21 120 pf Silver Dipped Mica Capacitor 6 120 or 121 / 500V
C25, C26, C27, C28
C29, & C30 .1uf Ceramic Disc Capacitor 6 .1 or 104
C22, C23, & C24 150 pf Metal Clad Capacitor 3 150
C34 22 uf Electrolytic Capacitor 1 22 uf / 25V
C35 10 pf Ceramic Disc Capacitor 1 10
VC1 25-150pf Tube in Tube Variable Capacitor 1 PSF# VC150
D1 3A / 1000V PIV Silicon Rectifier 1 1N5408
D2 1A / 1000V PIV Silicon Rectifier 1 1N4007
D3 Glass Signal Diode 1 1N4148
D4 LED Indicator assy. 1 Green LED / Resistor Pkg.
D5 LED Indicator assy. 1 Red LED / Resistor Pkg.
TR1, TR2, TR3, TR4,
TR5, & TR6 250 Watt RF Power Transistor 6 2SC2879
TR7 NPN Switching Transistor / TO-92 1 PN2222A
FC4, FC5, FC6, FC7
FC8, FC9, FC10
FC11, FC12, FC15,
& FC16 1/2” x 1/2” Ferrite Core 11 PSF# FC.5
FC1, FC2, FC3,
FC13, & FC14 1/4” x 1/2” Ferrite Core 5 PSF# FC.25
T1, T2, & T3 1/2” x 1/2” Ferrite Transformer Core 3 PSF# FT.5
T4, T5, & T6 1/2” x 2” Ferrite Transformer Core 3 PSF# FT2
SW1 SPST Switch 1 PSF# SW1
RLY1 DPDT Relay 12V Coil /10A Contacts 1 PSF# RLY10
FAN1 4.7” Fan Assy. 1 PSF# FAN4.7
FG1 4.7” Fan Guard 1 PSF# FG4.7
Conn1, Conn2 Panel Mount SO239 UHF Connector 2 PSF# SO-239B OR SO-239T
Conn3 1/4” Stereo Phone Jack 1 PSF# PJ-2
#12CW #12 Solid Copper Wire
(2 x 12” / L1 & L2 Loading Coils) 2
Cabinet Aluminum Enclosure Assy. 1 PSF# AE-EXLG
HS1 Aluminum Heat Sink 1 PSF# AHS-LG
CB1 Pre-Drilled Copper Clad Circuit Board 1 PSF# CCB-EXLG
CB2 Power Buss Circuit Board 6” x 3/4” 1 PSF# CCCB-.75X6
PS1, & 2 6 Position Pre-Cut Transistor / Pill Strips 2 PSF# PS6X
SCK1, & SCK2 LED Mounting Clip (with D4 & D5) 2
WIRE-1 #20 Silver/Teflon Wire
4-3/4” / Windings for FC1, FC2, & FC3 3 PSF# TEF20
WIRE-2 #16 Silver/Teflon Wire
8-3/4” Windings for T1, T2, & T3 3 PSF# TEF16
19” Windings for T4, T5, & T6 3 PSF# TEF16
8” Windings for FC4, FC5, & FC6 3 PSF# TEF16
6” Windings for SPLT1 & CMBR1 6 PSF# TEF16
3” Wire leads from RLY1 to CONN1 & 2 2 PSF# TEF16
WIRE-3 24” Length of #20 Hook-up Wire (Color 1) 1
WIRE-4 24” Length of #20 Hook-up Wire (Color 2) 1
WIRE-5 14” Length of #10 Red Power Cable 2
WIRE-6 14” Length of #10 Black Power Cable 2
COAX-1 RG316 Coax
7” Coax leads from SPLT1 to input
transformer windings 3 PSF# RG316
9” Coax leads from CMBR1 to output
HDW1 Hardware Kit (See Below)
SHCS #4 40 x 1/4” Socket screw 16
SHCS #6 32 x 1/4” Socket screw 12
Pan Head Sheet Metal Screw 6
Pan Head Machine Screw #6 32 x 1/2” 8
#6 Lock Washer 6
#6 32 TPI Machine Nut 4
#6 Solder Lug 5
Pan Head Machine Screw #8 32 x 1-1/2” 4
(Fan Mounting)
#8 32 TPI Machine Lock Nut (NYLOCK) 4
(Fan Mounting)
Rubber Feet 4
Grommet 1
Hole Plug 1
Scrap circuit board material 1
Heat sink lubricant 1
WESTGATE
Locked Previous topicNext topic
