Straight 4 Pill Amp Schematics - With Pictures
WESTGATE
Post by WESTGATE » Monday, 16 November 2009, 3:15 AM
parts list
R1, R2, & R12 4.7Ω 2W Carbon Film Resistor 3 Yellow-Violet-Gold
R3, R4, R5, & R6 10Ω 1/2W Carbon Film Resistor 4 Brown-Black-Black
R7, R8 R9, R10,
& R11 100Ω 2W Carbon Film Resistor 5 Brown- Black- Brown
VC1 Mica Compression Trim Capacitor 1 465
C1, C2, C3, C4, C17
C18, C19, & C20 .01 uf Ceramic Disc Capacitor 8 103
C5, & C6 330pf Silver Dipped Mica Capacitor 2 330 /500V
C7, & C8 1000pf Metal Clad Capacitor 2 1000
C9, C10 C11, & C12 120 pf Silver Dipped Mica Capacitor 4 120 / 500V
C13 1000 pf Silver Dipped Mica Capacitor 1 1000 or 102 / 500V
C14 150 pf Metal Clad Capacitor 1 150
C15 22 uf Electrolytic Capacitor 1 22 uf / 25V
C16 10 pf Ceramic Disc Capacitor 1 10
D1 3A / 1000V PIV Silicon Rectifier 1 1N5408
D2 1A / 1000V PIV Silicon Rectifier 1 1N4007
D3 Glass Signal Diode 1 1N4148
LED1 LED Indicator assy. 1 Blue LED / Resistor Pkg.
TR1, TR2, TR3,
& TR4 250 Watt RF Power Transistor 4 2SC2879
TR5 NPN Switching Transistor / TO-92 1 PN2222A
FC1, 2, 7, & 10 1/4” x 1/2” Ferrite Core 4
FC3, 4, 5, 6, 8, & 9 1/2” x 1/2“ Ferrite Core 6
T1, & T2 1/2” x 1/2” Ferrite Transformer Core 2
T3, & T4 .825” x 1-1/4” Ferrite Transformer Core 2
SW1 SPST Switch 1
RLY1 DPDT Relay 12V Coil /10A Contacts 1
FAN1 3.1” Fan Assy. 1
Conn1, Conn2 Panel Mount SO239 UHF Connector 2
Conn3 1/4” Stereo Phone Jack 1
Cabinet Aluminum Enclosure Assy. 1
HS1 Aluminum Heat Sink 1
CB1 Pre-Drilled Copper Clad Circuit Board 1
CB2 Copper Clad Circuit Board 5-1/8” x 3/4” 1
PS1, & 2 4 Position Pre-Cut Transistor / Pill Strip 2
SCK1 LED Mounting Clip w/ LED Assy. 1
WIRE-1 9-1/2” Length of #20 Silver/Teflon Wire 1
WIRE-2 73.5” Length of #16 Silver/Teflon Wire 1
WIRE-3 21” Length of #14 Silver/Teflon Wire 1
WIRE-4 16” Length of #20 Hook-up Wire (Color 1) 1
WIRE-5 12” Length of #20 Hook-up Wire (Color 2) 1
WIRE-6 12” Length of #10 Red Power Cable 1
WIRE-7 12” Length of #10 Black Power Cable 1
COAX 6” Length RG316 Coax 1
HDW1 Hardware Kit (See Below)
SHCS #4 40 x ¼” Socket screw 10
SHCS #6 32 x ¼” Socket screw 8
Pan Head Sheet Metal Screw 4
Pan Head Machine Screw #6 32 x ½” 4
#6 Lock Washer 2
#6 32 TPI Machine Nut 4
#6 Solder Lug 3
Pan Head Machine Screw #8 32 x 1-1/2” 4
#8 32 TPI Machine Lock Nut (Nylock) 4
Rubber Feet 4
Rubber Grommet 1
Scrap circuit board material 1
Heat sink lubricant 1
WESTGATE
