8 Pill Amp Schematics - With Pictures
WESTGATE
Post by WESTGATE » Monday, 16 November 2009, 2:45 AM
parts list
R24 4.7Ω 2W Carbon Film Resistor 1 Yellow-Violet-Gold
R4, R13, R14, R15,
R16, R17, R18, R19,
& R20 100Ω 2W Carbon Film Resistor 9 Brown- Black- Brown
R5, R6, R7, R8,
R9, R10, R11, & R12 10Ω 1/2W Carbon Film Resistor 8 Brown-Black-Black
R21, R22, & R23 100Ω 5W Metal Film Resistor 3 Brown- Black- Brown
C1, C3, C5, & C7 270pf Silver Dipped Mica Capacitor 4 270 or 271 / 500V
C2, C4, C6, & C8 1000pf Metal Clad Capacitor 4 1000
C9, C10, C11, C12,
C13, C14, C15, &
C16 .01uf Ceramic Disc Capacitor 8 103 or .01
C17, C18, C19 C20,
C21, C22, C23, &
C24 120 pf Silver Dipped Mica Capacitor 8 120 or 121 / 500V
C25, C26, C27, C28
C29, C30, C31, &
C32 .1uf Ceramic Disc Capacitor 8 .1 or 104
C33, & C34 150 pf Metal Clad Capacitor 2 150
C35 25-150pf Tube in Tube Variable Capacitor 1 PSF# VC150
C36 22 uf Electrolytic Capacitor 1 22 uf / 25V
C37 10 pf Ceramic Disc Capacitor 1 10
C38 150 pf Silver Dipped Mica Capacitor 1 150 or 151 / 500V
VC1 Mica Compression Trim Capacitor 1 465 PSF# VC465
SPLT1 1/2" x 1/2" Torroidal Splitter 1 PSF# SPLT-4
CMBR1 1-1/8” x 1/2" Torroidal Combiner 1 PSF# CMBR-6
D1 3A / 1000V PIV Silicon Rectifier 1 1N5408
D2 1A / 1000V PIV Silicon Rectifier 1 1N4007
D3 Glass Signal Diode 1 1N4148
D4 LED Indicator assy. 1 Green LED / Resistor Pkg.
D5 LED Indicator aasy. 1 Red LED / Resistor Pkg.
TR1, TR2, TR3, TR4,
TR5, TR6, TR7,
& TR8 250 Watt RF Power Transistor 8 2SC2879
TR9 NPN Switching Transistor / TO-92 1 PN2222A
FC1, FC2, FC7, FC8,
FC9, FC10, FC11,
FC12, FC15 & FC16 1/2” x 1/2” Ferrite Core 10 PSF# FC.5
FC3, FC4, FC5, FC6
FC13 & FC14 1/4” x 1/2” Ferrite Core 6 PSF# FC.25
T1-A, B, C, & D 1/2” x 1/2” Ferrite Transformer Core 4 PSF# FT.5
T2-A, B, C, & D .825” x 1-1/2” Ferrite Transformer Core 4 PSF# FT.825
SW1 SPST Switch 1 PSF# SW1
RLY1 DPDT Relay 12V Coil /10A Contacts 1 PSF# RLY10
FAN1 4.7” Fan Assy. 1 PSF# FAN4.7
FG1 4.7” Fan Guard 1 PSF# FG4.7
Conn1, Conn2 Panel Mount SO239 UHF Connector 2 PSF# SO-239B OR SO-239T
Conn3 1/4” Stereo Phone Jack 1 PSF# PJ-2
Cabinet Aluminum Enclosure Assy. 1 PSF# AE-EXLG
HS1 Aluminum Heat Sink 1 PSF# AHS-LG
CB1 Pre-Drilled Copper Clad Circuit Board 1 PSF# CCB-EXLG
CB2 Power Buss Circuit Board 8” x 1” 1 PSF# CCCB-1x8
CB3, & 4 Combiner / Splitter Mounting Board 2 PSF# CSMB-5/8x2-1/4
PS1, & 2 8 Position Pre-Cut Transistor / Pill Strips 2 PSF# PS8X
SCK1, & SCK2 LED Mounting Clip (with D4 & D5) 2
WIRE-1 20” Length of #20 Silver/Teflon Wire 1 PSF# TEF20
WIRE-2 183” Length of #16 Silver/Teflon Wire 1 PSF# TEF16
WIRE-3 24” Length of #20 Hook-up Wire (Color 1) 1
WIRE-4 24” Length of #20 Hook-up Wire (Color 2) 1
WIRE-5 14” Length of #10 Red Power Cable 2
WIRE-6 14” Length of #10 Black Power Cable 2
COAX-1 8” Length RG316 Coax 1 PSF# RG316
COAX-2 10” Length RG8-XX Coax 1 PSF# RG8-XX
HDW1 Hardware Kit (See Below)
SHCS #4 40 x 1/4” Socket screw 20
SHCS #6 32 x 1/4” Socket screw 12
Pan Head Sheet Metal Screw 6
Pan Head Machine Screw #6 32 x 1/2” 8
#6 Lock Washer 6
#6 32 TPI Machine Nut 4
#6 Solder Lug 5
Pan Head Machine Screw #8 32 x 1-1/2” 4
(Fan Mounting)
#8 32 TPI Machine Lock Nut (NYLOCK) 4
(Fan Mounting)
Rubber Feet 4
Grommet 1
Hole Plug 1
Scrap circuit board material 1
Heat sink lubricant 1
Label Sheet 1
4” Cable Tie 4
WESTGATE
