1 Pill Amp Schematics - With Pictures
WESTGATE
Post by WESTGATE » Sunday, 15 November 2009, 19:49 PM
parts list is listed in part2
continued in 1 pill amp schematics"part2"
WESTGATE
WESTGATE
1 pill amp schematics "part 2"
Post by WESTGATE » Sunday, 15 November 2009, 20:03 PM
continued from part 1
parts list
R1 4.7Ω 2W Carbon Film Resistor 1 Yellow-Violet-Gold
R2 100Ω 2W Carbon Film Resistor 1 Brown- Black- Brown
R3 10Ω 1/2W Carbon Film Resistor 1 Brown-Black-Black
VR1 100Ω 2W Potentiometer 1 Labeled
C1 100~180 pf Silver Dipped Mica Capacitor 1 100~180 / 500V
C2, C3, C4 1000 pf Ceramic Disc Capacitor 3 1000, 102, or .001
C5, C6, C7, C8 .1 uf Ceramic Disc Capacitor 4 0.1, or 104
C9 1000 pf Silver Dipped Mica Capacitor 1 1000 or 102 / 500 or 1000V
C10 120 pf Silver Dipped Mica Capacitor 1 120 or 121 / 500V
C11 150 pf Silver Dipped Mica Capacitor 1 150 or 151 / 500V
C12 22 uf Electrolytic Capacitor 1 22 uf / 25V
C13 22 pf Ceramic Disc Capacitor 1 22
C14 .03 uf Silver Dipped Mica Capacitor 1 Large Cap. (Not Labeled)
D1 3A / 1000V PIV Silicon Rectifier 1 1N5408
D2 1A / 1000V PIV Silicon Rectifier 1 1N4007
D3 Glass Signal Diode 1 1N4148
D4 LED Indicator assy. 1 Blue LED / Resistor Pkg.
TR1 250 Watt RF Power Transistor 1 2SC2879
TR2 Switching Transistor / TO-92 1 PN2222A
FC1, & 2 ½” x ½” Ferrite Core 2 PSF# FC.5
FC3, & 4 ¼” x ½” Ferrite Core 2 PSF# FC.25
T1 ½” x ½” Ferrite Transformer Core 1 PSF# FT.5
T2 ½” x 1” Ferrite Transformer Core 1 PSF# FT1
SW1 SPST Switch 1 PSF# SW1
RLY1 DPDT Relay 1 PSF# RLY5
Conn1, Conn2 Panel Mount SO239 UHF Connector 2 PSF# SO239
Cabinet Aluminum Enclosure Assy. 1 PSF# AE-SM
HS1 Aluminum Heat Sink 1 PSF# AHS-SM
CB1 Pre-Drilled Copper Clad Circuit Board 1 PSF# CCB-SM
CB2 Copper Clad Circuit Board (Power Bus) 1
PS1, & 2 Pre-Cut Transistor / Pill Strips 2 PSF# PS8X
SCK1 LED Mounting Clip (Packaged w/ LED) 1
KB1 Control Knob 1
WIRE-2 21” Length of #16 Silver/Teflon Wire 1 PSF# TEF16
WIRE-3 19” Length of #20 Silver/Teflon Wire 1 PSF# TEF20
WIRE-4 8” Length of #20 Hook-up Wire (Color 1) 1
WIRE-5 8” Length of #20 Hook-up Wire (Color 2) 1
WIRE-6 12” Length of #12 Power Cable 1
COAX 7” Length RG316 Coax 1 PSF# RG316
HDW1 Hardware Kit (See Below)
SHCS #4 40 x ¼” Socket screw 4
SHCS #6 32 x ¼” Socket screw 4
Pan Head Sheet Metal Screw 4
Pan Head Machine Screw #6 32 x ½” 4
Circuit Board Spacer Washer 4
#6 Lock Washer 2
#6 32 TPI Machine Nut 4
#6 Solder Lug 2
Rubber Feet 4
Rubber Grommet 1
Scrap Circuit Board Material 1
Heat sink lubricant 1
WESTGATE
