New to ssb.
- Real Name: Brad
- Antenna: hustler &imax
- Radio: galaxydx98 &dx55
New to ssb.
Ok....I need a little help understanding ssb....I have flipped over on lsb a time or two but never heard anyone...maybe I didn't have conditions or was on wrong channel....thought maybe it was unused in Texas or maybe my mobile(dx98 galaxy) couldn't receive it....someone give me an idea of the channels to try please.
thanks
605texas!
thanks
605texas!
- silvereagle1
- Handle: Silver Eagle
- Real Name: Mark
- Antenna: Sirio Turbo 5000
- Radio: President Lincoln 2
Re: New to ssb.
put it on 38 lower side and listen for a little while. Call out and see if there might be some locals listening. When you start hearing a lot of DX you'll be able to hear a ton of stations on sideband. 36-40 with 38 having the most traffic usually. I love the SSB portion of the radio that's about all I do myself.
President Lincoln 2
Sirio Turbo 5000 Roof Mount
567 East Tennessee
567 East Tennessee
- Real Name: Brad
Re: New to ssb.
Thanks silvereagle1!
- silvereagle1
- Real Name: Mark
Re: New to ssb.
you'll have to use the clarifier to tune them in though. two different stations in the background might not tune in the same. but you can normally keep your clarifier at 12 o'clock with good results. sometimes there are stations you can't tune in at all and some you have to tune them in maxed out to the right or left but for the most part you should be alright at 12 o'clock with most stations. if you live in cold tempatures it might drift just a tad in the winter time. my galaxy did but it wasn't bad.
President Lincoln 2
567 East Tennessee
567 East Tennessee
- Real Name: Brad
Re: New to ssb.
My galaxy only drifts 1pt. Unless its below 20f normally (on am)...I will keep an eye on it. Next question is....will my rx/tx be better on ssb in my mobile? Also my radio on ch38lsb keys 0 & swings to max(250w) when I call out on it....is that normal?
Thanks
605
Thanks
605
Re: New to ssb.
There is no carrier (dead key) on SSB, it's all swing. Depending on if that radio has a 5 or 6 digit frequency counter 1 point might be a lot. Just being a tiny bit off frequency will make communication difficult. Your range will increase on ssb since it is a more efficient mode. I don't consider ssb communication better but some really like it.605texas wrote:My galaxy only drifts 1pt. Unless its below 20f normally (on am)...I will keep an eye on it. Next question is....will my rx/tx be better on ssb in my mobile? Also my radio on ch38lsb keys 0 & swings to max(250w) when I call out on it....is that normal?
Thanks
605
