The New Dx Directory
COMING SOON!
I bought a Cobra SR900 at a Pawn Shop
a place to talk about and ask for help for them shortwave radio's & Scanners
TURNz
Post by TURNz » Monday, 12 October 2009, 12:25 PM
I found a Cobra SR900 in a Pawnshop for $15. It had the manual and a power supply. Manufacture date is 1990.
Is this a good one? I know it's old as hell. It seems to work fine.
I can't find much info on the web except for some sites selling them or the manuals.
Re: I bought a Cobra SR900 at a Pawn Shop
Post by 'Doc » Monday, 12 October 2009, 18:41 PM
If it works at all, you more than got your money's worth for that price. Is it the absolute most bestest thing since crystal radios? I sort of doubt it. Will it work in most cases? Probably as good as any other scanner, just depends on what you want to listen to and how those services are set up in your area. Higher antennas work better than lower antennas. From there, you're on your own.
lucas
Radio: Cherokee CBS-1000
Home Phone: channel one
Post by lucas » Wednesday, 14 October 2009, 16:49 PM
depends where you live too...if your trying to listen to police or in my case RCMP, there are some places that have switch over to a new system (some one will chime in here and tell me what system that is) but in any case you cant listen to them anymore, BUT only in some areas,(yours may not be one of these areas) i know of one here in canada for sure that you cant pick them up and that down in the southern area of nova scotia.
The only reason i have a scanner is for the coast guard, and boats out in the waters around my area here in newfoundland, and once in a while i'll throw in the RCMP freq for a good laugh :P...AHAHAHAH
TRC 449
TRC 242
TRC 454 (FUN FUN) (8) Ring ring ring BANNANA phone (8)
Uniden 68XL
K-40
Antron 99
Home made ground plane
TURNz
Post by TURNz » Thursday, 22 October 2009, 4:00 AM
Ok, so I moved this thing outside last night to listen while we carved pupkins. I input a bunch of new channels that I found. All was working well. Then I moved it back inside. It was unplugged for less than a minute. All channels were lost.
Is there a battery inside that I can change? I am going to open it up tonight and see.
MoJo
Radio: Uniden 68, TR 696FD1
Home Phone: 2314211186
Post by MoJo » Thursday, 22 October 2009, 5:44 AM
lucas wrote:depends where you live too...if your trying to listen to police or in my case RCMP, there are some places that have switch over to a new system (some one will chime in here and tell me what system that is) but in any case you cant listen to them anymore, BUT only in some areas,(yours may not be one of these areas) i know of one here in canada for sure that you cant pick them up and that down in the southern area of nova scotia.
It's called trunking...
They transmit and receive on different frequencies.
A trunking scanner will pick those up.
Post by 'Doc » Thursday, 22 October 2009, 9:55 AM
Any scanner (or radio) with programmable memories should have a battery in there that will keep those memory chips 'active'. And then there are memory chips that do not require a battery (less common). You might take a look and see if you can find a small battery. If so, then swap the thing for a new one, they do 'retire' when they get old enough. There's also usually a charging or maintenance circuit for those batteries. If the thing was left idle long enough, that circuit is probably okay and the battery just died. Wait and see, sort of.
