Any one know how to disable the low battery beep on the pro-2006 scanner. I have put in a new battery and have also checked the voltage @ the board for 9 volts and have it there. The scanner does not loose its memory while unpluged so I know its seeing the needed 9 volts. But the beep is still there. I either need it disabled or repaired.
Thanks
Hacksaw
Low battery beep on the pro-2006
- North Texas Mudduck
