Galaxy 99v
drew434
Cell Phone: 16062723865
Galaxy 99v
Post by drew434 » Sunday, 16 April 2017, 20:29 PM
I need some help with a galaxy 99v the radio receive good and transmit good you can put it in a truck and go to hook the antenna cable to it and it will shut off just like you turn it off it don't do it all the time thank you
Logged in via: iPhone
Re: Galaxy 99v
Post by MDYoungblood » Monday, 17 April 2017, 5:11 AM
It sounds like you have either a bad connection in the truck or the radio has a cold solder joint, possibly both. Is it shutting down after a long conversation or just as you are riding, vibration might be the clue.
drew434
Re: Galaxy 99v
Post by drew434 » Monday, 17 April 2017, 5:16 AM
I can hook it the right antenna on my truck and it will work good I can hook it to the lift antenna and it will go off just as soon as you put the coax in the back
Re: Galaxy 99v
Post by MDYoungblood » Monday, 17 April 2017, 5:22 AM
By off you mean no sound or static, or does the radio go dead like the power has been disconnected?
Re: Galaxy 99v
Post by sonoma » Monday, 17 April 2017, 5:23 AM
sounds like a bad antenna or coax. if it only does it on the little antenna. you will need to find the problem with the antenna
drew434
Re: Galaxy 99v
Post by drew434 » Monday, 17 April 2017, 17:02 PM
It just goes dead like you remove the power cord
Re: Galaxy 99v
Post by sonoma » Monday, 17 April 2017, 17:06 PM
does the lights and all go out when you hook up the antenna. also check to see if it does this when you just put the end of the coax inside the plug and do not let the ground touch the radio.
Re: Galaxy 99v
Post by MDYoungblood » Monday, 17 April 2017, 17:23 PM
I didn't think a Galaxy radio has a protection circuit to cut the radio off if the antenna shorts but it seems that is what's happening. Check the left antenna and see if it is indeed shorted out. Check the coax with a multi meter, if you can disconnect the coax from the mount, check it that way too. Check any insulators the antenna stud mount is using, could be a short there.
