Ok here is my question . I want to install a potentiometer for my talk back i just need want to make sure im doing it correctly. Three legs looking at the top front left leg to ex speaker, Middle leg to pa, Right leg to ground?
-- Tuesday, 21 February 2017, 8:07 AM --
also this is a cobra 29 ltd
talk back
- 295 antenna
- Moderator
- Handle: 2950 or 295
- Real Name: Charles Reney
- Antenna: patriot, Discone
talk back
- sonoma
- Handle: sonoma
- Real Name: sonoma
- Radio: President Washington
Re: talk back
295 here is a page showing how to do talk back for a 25/29 radio. you lost me as to where you were going to put the wires. so this pic should work fine. all you need is 2 legs. after you wrote, speaker PA then ground I was not sure where you were putting it.
http://downloads.cobra.com/CB ... B10056.pdf
- 295 antenna
- Moderator
Re: talk back
Thank you sonoma exactly what i needed
Re: talk back
On the resistor mod I just add a micro switch inline on the negative side of the resistor to turn it off.
