Channel King 500 schematic?
- mbuccione
- Mud-Duck Sr.
- Real Name: mbuccione
Hello there,
I am wondering if anyone has the schematic and manual for the "channel King 500+" linear amp.
Thank you
Thank you
- mbuccione
- Mud-Duck Sr.
Re: Channel King 500 schematic?
No one? I guess it was made by a gost company....
- Nagant
- Real Name: Paul
- Antenna: M104C, V-Quad
- Radio: To Many To List
Never heard of or seen that one before. Is it transistorized or a tube amp?
- mbuccione
- Mud-Duck Sr.
- Night Crawler
If you can't find a schematic follow the circuit wiring and draw your own that's what I would do.
- Nagant
- Real Name: Paul
That's a new one to me. Likely a small long forgotten builder. Finding a manual and schematic for it will be next to impossible more than likely. It wouldn't be of much use on amateur bands as it's a sweep tube amp with a drive section. Therefore you're right that it was meant more for the CB market.
- mbuccione
- Mud-Duck Sr.
- Night Crawler
- mbuccione
- Mud-Duck Sr.
- Night Crawler
Hard to tell from the picture but it looks like one of the filament and HV wires is disconnected.
When you power it up here's a trick to use to prevent any further damage to the amp.
Take an extension cord cut one side and install a socket for a light bulb in series with it use a 100 watt bulb.When the extension cord is connected between the equipment to be tested and the 120 volt power source the bulb will take the surge of the current,if there is no short the bulb will glow bright at first then go to a dull orange if it stays bright you have a short somewhere.
- mbuccione
- Mud-Duck Sr.
Thank you for the tip, I'll try it when I'll be back home as I am out of the town but still I wish somebody can provide me the original schematic and some information about that amp as it is a good vintage piece of equipment.Night Crawler wrote:Hard to tell from the picture but it looks like one of the filament and HV wires is disconnected.
- hammerjockey
- Handle: hammerjockey
- Real Name: andrew
- Radio: rci 2990
Hey, digging up a fossil thread but wondering if you ever found any info on the channelmaster 500? I'm buying one this week to restore, hoping to find as much info as possible on it! Thanks guys.
