Dosy SW-4 antenna switch
Help with installing an Antenna, or just choosing the right antenna to go with your radio, or your mobile.
HOUND DOG
Post by HOUND DOG » Sunday, 02 July 2017, 7:16 AM
Is anyone using this dosy switch for a dual polarity yagi beam and is there any benefit to transmitting with this switch in the combination, Vert./Horiz. position? I presently use a Delta 1500 watt A-B switch.
*In a Galaxy far far away*
Logged in via: iPhone
Re: Dosy SW-4 antenna switch
Post by MDYoungblood » Sunday, 02 July 2017, 8:03 AM
Years ago I had the Dosy meter with the V/H/D/aux switch, I used it a couple times and never really seen any difference except for the SWR went way up. I never looked inside to see how it was wired to do the dual polarity. I think the delta switch is a much better choice, it not only has better separation of the coax but grounds the unused coax/polarity. Be sure to run a ground wire to it from a rod outside or a cold water pipe if they are copper.
Users browsing this forum: No registered users and 4 guests
