Beam Height above tower and rotor
RodinKy
Real Name: Rod Eagan
Antenna: IMAX 2000/Maco Comet
Radio: DX2517 & Mark IV
#384889
Post by RodinKy »
My beam gamma match is just barely above the top of the tower and rotor and my swr is higher than what it should be, can increasing the height above the tower effect my swr? The bottom elements are below the top of the tower.
Re: Beam Height above tower and rotor
#384890
Mine the elements are maybe a foot lower than the top of the tower, but SWR is fine...not perfect, but under 2.0
#384894
JJD pic shows an excellent install, here is one I did back in the mid 70's, still up today.
ImageMoonraker IV on a 40ft Rohn 25G tower
It is best to get the driven element away from the tower top as much as possible.
RodinKy
#384925
Post by RodinKy »
Thanks JJD and MDY looks like I need too make some modifications
