The New Dx Directory
COMING SOON!
5 Element Beam/Coax Length
RodinKy
Radio: DX2517 & Mark IV
Antenna: IMAX 2000/Maco Comet
Post by RodinKy » Monday, 17 April 2017, 3:59 AM
Bought a beam from an individual and it has about 100 ft of RG8 coax attached, which is about 60ft more than I need. I was told by the previous owner not to shorten it because it would change the SWR. Is this true?
PA629
Re: 5 Element Beam/Coax Length
Post by PA629 » Monday, 17 April 2017, 4:07 AM
If coax length changes SWR, then you have other issues with the antenna system's tuning. Changing coax length can make you see a different reading on an SWR meter, but it's simply a band-aid, not a cure. Coax length is just another 11 Meter Myth.
Base: Galaxy DX2517, D104 Silver Eagle w/W2ENY element, SB 220, Imax 2000, 4 element quad
Mobile: Galaxy 95T2, Astatic 575-M6, Sirio P-5000 Performer, Unmentionable 4x2879
Slim Pickins
Radio: Realistic Navajo 457
Post by Slim Pickins » Monday, 17 April 2017, 4:20 AM
There is a pretty good chance you will see a change in SWR just by swapping the entire setup from his place to yours. There are a lot of factors that can affect what you see on a meter. Just put it up with the cable you need and tune for best performance at your location.
[ Post made via iPad ] Image
73,Slim
Post by MDYoungblood » Monday, 17 April 2017, 4:57 AM
Like the others said, coax shouldn't change the SWR but you will probably be taking the antenna apart to transport it to your house. If you don't have a manual to put it back together you can most likely find it on the antenna manufacturer's website or CB Tricks. I would take a real good look at the old coax and since you only need half buy a new 50ft length, would be better off with new to start out fresh.
