The New Dx Directory
COMING SOON!
SR-A10 Question?
kidx
Antenna: Uniden PC787
SR-A10 Question?
Post by kidx » Wednesday, 01 February 2017, 16:58 PM
I have a SR-A10 and on the, Radio it is telling me its no where under 2.0 SWR. Yet I hook up the Astatic PDC2 SWR Meter and its under 2.0 what is right?
Re: SR-A10 Question?
Post by MDYoungblood » Wednesday, 01 February 2017, 17:53 PM
How and where is it mounted?
kidx
Post by kidx » Wednesday, 01 February 2017, 18:07 PM
Well its mounted to a firestik, http://www.firestik.com/Catalog/IBA5.htm" onclick="window.open(this.href);return false; I was told it would work by Stryker. So far so good but the radio says other wise yet the SWR meter says its in check. I also was told to use an external SWR meter witch I have done.
Post by MDYoungblood » Wednesday, 01 February 2017, 18:44 PM
I've never used that indoor antenna, I really don't care much for FireStik. Did you try the antenna that came with that base to see if the SWR is any better? Where is the antenna located, inside or out, inside you would have an SWR problem because of the surroundings.
kidx
Post by kidx » Wednesday, 01 February 2017, 21:10 PM
Well its out side, I am also running a lowpass filter lol or RF Limiter.
Post by sonoma » Wednesday, 01 February 2017, 21:12 PM
what radio are you using, did I miss that info some where. do you have the antenna on some kind of pole? it needs to be off the ground.
kidx
Post by kidx » Wednesday, 01 February 2017, 22:17 PM
Well its off the ground and I am using the Uniden PC787.
Post by sonoma » Thursday, 02 February 2017, 0:35 AM
just wondering what radio. the cobra 29 radios are bad about the swr light portion is out of spec causing the issue you are having. do not know of an adjustment for the radio you have. way to new to have ran across one as of yet
kidx
Post by kidx » Thursday, 02 February 2017, 0:49 AM
My radio is good now i am happy.
Post by sonoma » Thursday, 02 February 2017, 2:43 AM
what did you do to get the swr problem taken care of. some one else may have the problem and what ever you did might help them. any fix you guy's should post it for some one else in the future.
Post by MDYoungblood » Friday, 03 February 2017, 10:11 AM
kidx wrote:My radio is good now i am happy.
So what was the problem? I would like to know too.
kidx
Post by kidx » Sunday, 05 February 2017, 14:16 PM
I run a RF Limter DF3000, From RF Limited works well after I raised my antenna to the highest to get 1.5 SWR.
-- Friday, 03 March 2017, 7:59 AM --
Just to let you know dont run a RF limiter, With out the limiter its like 2.5 plus with it is 1.5 SWR weird.
