Moxon beam
- Mtn Lynx
- Handle: Lightning
- Real Name: Cletus
- Call Sign: WR223
- Antenna: A99/Wire dipole
- Radio: Anytone AT 6666/Bearcat 980SSB
Moxon beam
I've been reading about Moxon Antennas and saw that HomerBB made one with a walker. Saw that mfj makes one, and it performed really well on a YouTube video where one dude from Ottawa was talking skip on 3 watts. Got me interested. I'm ordering some 3/4" aluminum tubes and some supplies to make my own Moxon using HomerBB's schematics. It looks simple enough and a good way to pass the time. :r&r:
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Re: Moxon beam
Decent forward gain and a great F/B ratio for a couple spreaders and 2 pcs. of wire. I've made a couple for temporary field day usage.
Re: Moxon beam
Maybe if you get the one working for you then you can try this,
3'sGreg
Re: Moxon beam
Sweet...a dual polarity. I've made one of those and it worked terrific.MDYoungblood wrote:Maybe if you get the one working for you then you can try this,3's
I used copper tubing on mine vs. aluminum. I simply soldered 90* elbows and kept me from having to bend the aluminum. I have tubing benders but all the stuff I used on mine were bought at my local Home Depot & Ace Hardware stores. Awesome F/B & F/S ratio at any height. I will tell you that the vertical calculator is off some on the moxon antenna project calculation tool...but the Moxon is one of the best small beams I've ever had the pleasure of using. Even wire elements (which I've made several of for different bands) work very well...but not as well as tubing.
Good luck.
231
- HomerBB
- Handle: Homer, 2WR183, Country Preacher
- Real Name: Charles
- Call Sign: K5HBB
- Radio: IC-746
Re: Moxon beam
Love the Moxon.
After 2 years of faultless performance in the air I just brought it down to use its mast for testing another antenna.
A friend obtained a 1970's Cushcraft CR-1 Ringo antenna and wanted me to try to get it to tune up. I did, and it does. I had to make another stub for it, but it works quite well.
Back to the Moxon.
I agree that the tubing Moxon out performs the wire versions i built. Its an easy to build small beam that never dissappoints,
Back to the Moxon.
It's Not Crazy, If It Works
The 11 Meters MacGyver
- Mtn Lynx
- Handle: Lightning
- Real Name: Cletus
- Call Sign: WR223
Re: Moxon beam
Weather has not been cooperating and I have not found the time to start on the antenna yet. The days are getting longer, and hopefully warmer soon. It's been in the - degrees below zero for awhile. the plan to construct the Moxon is still going to happen.
Thanks HomerBB
Thanks HomerBB
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
- HomerBB
- Call Sign: K5HBB
- Radio: IC-746
Re: Moxon beam
- Mtn Lynx
- Handle: Lightning
- Real Name: Cletus
- Call Sign: WR223
Re: Moxon beam
Had trouble finding scraps for the build. So ordered a Mfj 1890, it came today. When weather permits I will set it up.
[ Post made via iPad ]
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
- HomerBB
- Call Sign: K5HBB
- Radio: IC-746
Re: Moxon beam
231 wrote: ↑January 13th, 2017, 11:51 amSweet...a dual polarity. I've made one of those and it worked terrific.MDYoungblood wrote:Maybe if you get the one working for you then you can try this,3's
Good luck.
231
Yes the vertical dimensions are shorter because the antenna is seeing the metal mast and the coax from both.
Re: Moxon beam
Now the dimensions are slightly longer for 11m.
- Mtn Lynx
- Handle: Lightning
- Real Name: Cletus
- Call Sign: WR223
Re: Moxon beam
Thanks MD, I saw a fella on YouTube set one up for 11m. His measurements were hard to read. I think he was 3/4 inch more at each corner
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Re: Moxon beam
You could try this calculator, the tubing average is around 13mm (1/2") so put that in the "Wire Dia." then just add the center frequency you want to use.
- Real Name: MichaelPannyPG
Moxon beam
Can’t you cut the adjusters off the the beam, rotate them and re weld them on again?
Re: Moxon beam
Need a little more info on what adjuster's you are talking about?MichaelPanny wrote: ↑July 24th, 2018, 11:19 am Can’t you cut the adjusters off the the beam, rotate them and re weld them on again?
3'
- Mtn Lynx
- Handle: Lightning
- Real Name: Cletus
- Call Sign: WR223
Re: Moxon beam
Man, i haven't got around to installing the moxon yet. It's just sitting in storage as a future project. It'll get up b4 next solar maximum. Lol
[ Post made via Android ]
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
