Sirio 145 PL mag mount coax
- millguy
- Handle: millguy
- Real Name: Jeff Q
- Call Sign: Kcorep
- Radio: Stryker 955
Does the radio end of the coax come with the removable connector like the Wilsons do to make running through grommets and firewalls easier?
- milkman21218
- Handle: Milkman
- Real Name: Izzy
- Call Sign: W1ASA
- Radio: Many
- millguy
- Handle: millguy
- Real Name: Jeff Q
- Call Sign: Kcorep
Re: Sirio 145 PL mag mount coax
Ah. Ok thanks a lot.milkman21218 wrote:No it's fixed.
I like the Sirio mount because the coax can be changed out easier than the Wilson mounts. Solder you are capable of soldering a new coneector just clip the original off and run the coax or remove the 4 screws from the mount, unsolder the coax, run it and resolder.
I never liked those connectors that were two parts, the same one was on the K40 mounts, it would come loose and the SWR wouls sky rocket.
- army1975
- Handle: Proud American
- Real Name: Keith Goodman
- Antenna: Wilson 5000
- Radio: Galaxy DX-979
do what I did to my lil pick'em-up truck, break out the drill an drill the hole bigger.
CB Handle: PROUD AMERICAN
SEPTEMBER 11, 2001.......Our Loss Will Not Be FORGOTTEN
Veteran: Field Artillery. M40, 155 MM self-propelled howitzer. Bamberg, West Germany, 1975 - 1977.....HOOAH!!
