Antenna tuner
Tell us what you're doing from day to day. Post your daily notes here about any radio projects that you are working on.
295 antenna
Handle: 2950 or 295
Real Name: Charles Reney
Antenna: patriot, Discone
Radio: Stryker 955 , Browning Mark iv
Antenna tuner
#385137
Post by 295 antenna »
does anybody know if this one is good.
MFJ-962D VERSA TUNER III 1.5 KW ROLLER INDUCUCTOR TUNER
Re: Antenna tuner
#385159
This is one of those "it all depends" answers, new and getting a great deal then "yes". Getting one used, inspect it for arc's in the air caps. I never had one but something similar and most reasons they are sold used is arcing.
295 antenna
Handle: 2950 or 295
Re: Antenna tuner
#385187
what causes the arcing ? i havent got it yet but now im curious
Re: Antenna tuner
#385192
Look between the cap blades for burnt spots. Most times it is because of over wattage.
295 antenna
Handle: 2950 or 295
Re: Antenna tuner
#385195
ok thanks . I haven't got it yet but good to know.
Re: Antenna tuner
#385267
I talked to a op yesterday that has one, runs his ALS 600 (500w+/-) to it with no problems, I think once you get over that wattage things start to arc.
bluemeanie
Handle: Blue
Real Name: Mark Schwab
Antenna: Max 2000 MACO M105
Radio: LOTS OF TUBES
Re: Antenna tuner
#385272
Post by bluemeanie »
Its a roller inductor. The little wheel that follows the winding if it has dirty spots on it they will arc on the wire. I have the same one used and they show some crusty spots. Look at carefully at it. If its burned it wont work right in that range.
