Finally dug out what I've kept, and buying some more
Tell us what you're doing from day to day. Post your daily notes here about any radio projects that you are working on.
liquidh8
Real Name: Flex
Antenna: Imax 2000
Radio: Cobra 148GTL
#325474
Post by liquidh8 »
Well, haven't been on the air in over 8 years. I am finally in a position with space and a bit of time to enjoy it again.
I dug out my IMAX2000, mounted it, for now, on a 6 foot mast on the chimney of my garage roof, which is about 15 foot tall. so that puts me roughly 45 feet to the tip I guess. I'll be replacing that mast with 20-30 or upper fence pipe soon!
I have an astron 11a power supply I had to replace a capp and diode in to fix. I am running my unknown branded 2 pill off it (2 sd1446's)
I have a little 4 amp power supply I use for the radio's, all little mobiles now. Uniden pro520 just for kicks, and a midland 77-115 I've had forever just for the channels.
The mic is an Astatic D104.
My meter is a DOSY test center.
Soon I'll be picking up a 148GTL for the mobile, and hopefully a president washington for a base. Pics soon.
FLEX 231 Southeastern PA Usually 27.385 LSB, 27.425 LSB, or whatever else I can talk on.
Radios: 858 Washington, 8719 Washington, Galaxy Saturn, HR2510's, TS-5010, 148GTL.
Amps: KLV1000, Eagle 515, KLV550, Palomar 225.
Antennas: Imax 2000, Wilson 5000.
Mics: Homebrew amplified Compressor, D104M6B's with tone mod.
dirtyjob
Handle: dirtyjob
Real Name: Mark
Antenna: Super Penetrator 500
Radio: Many
Re: Finally dug out what I've kept, and buying some more
#325477
Post by dirtyjob »
sounds good, nice to get back into the radio after years off
"LISTEN FOR THE PING"
Gizmotchy G-31 Beam
Super Penetrator 500 5/8 Wave
Comet GP9 2 meter/440
CBRT 18204
liquidh8
Real Name: Flex
Antenna: Imax 2000
Radio: Cobra 148GTL
#325481
Post by liquidh8 »
Sure is! This board also helps when you quick make a contact, some of the people I quick talked to are members. Really cool!
dirtyjob
Handle: dirtyjob
Real Name: Mark
Radio: Many
#325494
Post by dirtyjob »
yep thats true, puts a whole other aspect on talking skip that wasnt even available when most of us 1st got into radio.
Gizmotchy G-31 Beam
CBRT 18204
Island_0860
Handle: 860
Real Name: Johnnie
Antenna: 1/2 wave Dipole 2 EL Quad
Radio: SuperStar SS 158 EDX
#325505
Post by Island_0860 »
Enjoy "THE RUSH" .
with the first key up into DX LAND !
liquidh8
Real Name: Flex
Antenna: Imax 2000
Radio: Cobra 148GTL
#325658
Post by liquidh8 »
Lol. Well, I got my 148gt side mic today. Malaysia, 1992. I can't see a name on the board. MB8719 PLL looks like. It has R131 removed, I'll put that back I think. I took some pics, figured I'd edit my other thread and run with it for this radio.
liquidh8
Real Name: Flex
Antenna: Imax 2000
Radio: Cobra 148GTL
#325983
Post by liquidh8 »
Cobra 148GTL was never touched except for having R131 removed, which I like. So whatever i do to it I can document it and know what happens. I ordered upgraded caps, put R131 back but with a lesser value to get modulation at about 105% with the power mic way up. Gonna do channels. I read something about changing a few resistors and caps, to widen the bandwidth of the TX and RX filters, and another resistor, R206 I believe, to wide-band the TX. What exactly are these doing I wonder? New thread perhaps?
I also am a new owner of a President Washington, the one with 2 buttons, before Uniden I believe. Don't know what country it was made in. But I'll be researching uprades and mods for this too.
liquidh8
Real Name: Flex
Antenna: Imax 2000
Radio: Cobra 148GTL
#326220
Post by liquidh8 »
Here are some pictures.
The 148 GTL side mic, 01/1992 build date
Other stuff, power supplies, linear and some radios.
An old Midland 150M and a Realistic TRC-435 I think. The Midland just works, a few extra watts and modulation. The realistic I fixed, had a bad mic jack and internal speaker, little tune-up. Just playing around with them really
My 2 pill linear. I don't know who built it. I have had it for over 10 years. Had to fix a diode recently.
I think the 148GTL is close to done, just replaced all the old 10V dielectric caps for caps at least 16v, higher where they would fit. Put r131 back, got it set to DK at 2.5w and swing. Set up to run before my 2 pill, or a bigger one down the road. I'll add channels soon, maybe an expo kit. Or something I had seen on ebay and the net from Australia. I have the stuff in my garage, running into an IMAX antenna. I'll get that 20ft higher when i can buy the coax.
liquidh8
Real Name: Flex
Antenna: Imax 2000
Radio: Cobra 148GTL
#326926
Post by liquidh8 »
My President Washington came in the mail today, the two button older one. It works and sounds fantastic! The receive on the 148GTL was pretty good, after the shottky diodes and new transistor it got a bit better, but this thing is quiet! I am loving it. Modulation is only about 60% it seems, but it receives well!
Now to get info and schematics and mods and stuff for it and see what i want to do if anything. Probably just get the modulation up?
Pics to come
Island_0860
Handle: 860
Real Name: Johnnie
#326939
Hey liquidh8....
Been following your progress ..and your building the foundation for a nice DX Station using quality equipment.
Wish my 148 looked that good..
All the best
str8stroke
Real Name: Ric Flair
Antenna: 1/16 Wave Dipole
Radio: Gold Cobra 29LTD
#326952
Post by str8stroke »
That too pill looks very similar to a Cobra / Superstar / Polamar. Not to sure. Others may know better.
liquidh8
Real Name: Flex
Antenna: Imax 2000
Radio: Cobra 148GTL
#326959
Post by liquidh8 »
Island_860, thanks!
srt8stroke, I Though so too. But the polamar has a different PCB from what I can find on them. I'll have to look into the cobra and superstars. It is messed up now anyway, it's way down on power.
liquidh8
Real Name: Flex
Antenna: Imax 2000
Radio: Cobra 148GTL
#326980
Post by liquidh8 »
Pics
Nagant
Real Name: Paul
Antenna: M104C, V-Quad
Radio: To Many To List
#326987
Post by Nagant »
Nice looking Washington. I've said it many times on the forum but I've grown very fond of the Uniden 858 PLL units like your Washington. Yes it pre dates having Unidens name on it but they still built them all. Does it say made in Japan on the back of the case? From my experience it seems all the 858 units were made in Japan just before Uniden switched production to Taiwan and rolled out the 8719 units.
liquidh8
Real Name: Flex
Antenna: Imax 2000
Radio: Cobra 148GTL
#326991
Post by liquidh8 »
I believe it does, I have to look again. I was so excited when I opened it, I just took pics, checked it, and started talking, lol
