Midnight's Install
Tell us what you're doing from day to day. Post your daily notes here about any radio projects that you are working on.
yMidnite
Real Name: Jim
Radio: Galaxy DX-959
Midnight's Install
Post by yMidnite »
I have been taling about the pedistal mount that was in progress... Not as far done as I would have liked, but I have pictures:
Mount built and assembled on bench.
Aproximate mounting position (from driver view)
Pieces painted.
Remaing to be done: run wires/cable from under dash to mount (trim an solder), screw down mount, connect and check. Hope to get it done this week... depends on weather.
Midnight Rider / 989 N FL
"We preserve our freedoms using four boxes: soap, ballot, jury, and cartridge." -- Anonymous
In Memory Of:
Marek Sajczuk 1/7/05 - 6/18/05 - My Son
Joe "Hawk" Sajczuk 6/22/42 - 3/15/90 - My Dad
Slim Pickins
Handle: Slim Pickins
Real Name: Paul
Call Sign: VE1PEW
Radio: Realistic Navajo 457
Re: Midnight's Install
Post by Slim Pickins »
Looking good. That amp looks familiar. :icon_e_wink: Can't wait to see her all lit up
Paul
73,Slim
weedge
Handle: naildriver
Real Name: Larry Jensen
Antenna: wilson 1000
Radio: Galaxy 949 cobra 148
Post by weedge »
midnite
Thats a great looking bracket. It gives me some ideas for my truck. I have a ford ranger and there is not any room under the dash, or not a good place with a stick shift. That mount would work between my seat and shifter. Looks Great.
Weedge
yMidnite
Real Name: Jim
Post by yMidnite »
Thanks for the compliments.
Wedge... it is amazing the lack of "dash" space that I have in my truck. Good luck with your design.
In Memory Of:
likes2grill
Real Name: Dan
Radio: Midland 79-290
Post by likes2grill »
Looks good ymidnite.
1394
721HACKSAW
Post by 721HACKSAW »
That is a great looking piece of workmanship there yMidnite, very good.
yMidnite
Real Name: Jim
Post by yMidnite »
I hope to have pictures by this evening. I have it all wired in and mounted... just need to clean up a few wires and it will be done.
In Memory Of:
yMidnite
Real Name: Jim
Post by yMidnite »
I finally finshed the little bit of clean up on the wires. School started this week, plus work, and the two year old... Saturday morning is the only time I had to finish.
You will see coming from under the dash the power, ground, and coax, I am not sure what I am going to do with that (maybe wire loom or something). I orginally was going to route it under the carpet (that is why the hole is in the back of the mount), but when I went to go do that I noticed it was rather warm under there. I decided I did not want to "cook" my cables, although it probably is no hotter than the roof.
Anyway here are the pictures:
Power is fused off the battery running an 8 gauge amp wire kit. Power runs into a fuse block which spilts to the radio and the amp. Radio is triple fused an the amp is double fused (prior to the fuses on the inside). I need to replace the one 30 amp fuse on the radio side of the fuse block with a smaller fuse (currently is a 30 amp), I will drop it to atleast a 20 amp but would prefer to put in a 10 amp if I can find it. Also the fuse under the hood is a 60 amp and I want to make it a 40 amp.
Lastly, I was looking at Gunny's site now that it is back up... I may (eventually when money and the nerve to drill holes in the roof) change my mag mount to one of those pucks.
In Memory Of:
linx
Post by linx »
Looks great yMidnight!
721HACKSAW
Great job, I love the mount, just add some 'snakeskin" loom. Very good work.
Slim Pickins
Real Name: Paul
Call Sign: VE1PEW
Great looking setup Midnight. I love seeing other people's installs. It can give you so many ideas for ways to install in different situations. It is nice that everything is visible from the driver's seat and within reach. Those fuse blocks are nice too and nice to have located where they are easily accessible.
73s
Paul
73,Slim
likes2grill
Real Name: Dan
Setup looks great. Nice and neat, sounds good too. It was nice talking to ya the other morning.
1394
yMidnite
Real Name: Jim
Post by yMidnite »
Thanks All
721HACKSAW wrote: just add some 'snakeskin" loom.
Not quite my style, but it gets the brain thinkin'...
likes2grill wrote:Setup looks great. Nice and neat, sounds good too. It was nice talking to ya the other morning.
It was good talking to you. I did not think that anyone else would be up that early.
In Memory Of:
armrdsaint
Handle: Armrdsaint
Real Name: michael
Antenna: 102'ss
Radio: cobra 29LTD, 29 NW
Post by armrdsaint »
That is a very nice looken set up ! I am impressed and like to see peoples ideas come to life. Be proud and catch ya on the site someday. AUDIOSSS from Nebraska
LOUD-N-PROUD
Radio Pig
Real Name: John
Antenna: Pigs Tail
Post by Radio Pig »
Thats awesome! Nice work. :cheers: Now you have given me an idea similar to yours for mounting in my Chevy silverado. That would make it much handier to use the radio while driving. Thanks for the idea!
Let us know how it all works out.
yMidnite
Real Name: Jim
Post by yMidnite »
Radio Pig wrote: Let us know how it all works out.
Ease of use is great... everything is at your finger tips.
Few things that have come up:
Depending on the location of the sun, the chrome reflects into the passangers eyes and can wash out the display
Vibration or shaking - I used tech screws to secure it and these do not pull it tight enough
To fix the shaking I will use (I can't think of the name) a threaded insert that works like a rivet and then I can tighten the mount to hopefully pull the shake out.
Good luck with your install.
In Memory Of:
Hondarider
Handle: Nick
Real Name: Nick
Antenna: A99
Radio: Cobra 29, Royce 632
Post by Hondarider »
Wow that looks sick! Looks pretty sturdy too. Best of luck with it.
Have a good one.
Hondarider
Hondarider
BobCB
Real Name: Bobby
Antenna: A99, Browning BR-140
Radio: Cobra 25LTD(varies)
Post by BobCB »
Gives me some ideas as well. I'm thinking of a few different options for putting a better radio in the Merc instead of just a 75-822.
854/BigDog in Central Alabama
rattlesnake
Real Name: chris
Radio: cobra 29 nw classic
Post by rattlesnake »
Nice setup....
199 OVER HERE IN CENTRAL FLORIDA...
rattlesnake
Real Name: chris
Nice setup....
015reddog
Handle: 015reddog
Real Name: REd
Antenna: Coathanger
Radio: Mudduck Junk
Post by 015reddog »
I want to do something like that in my mobile.
CAN YOU HEAR ME NOW?
