Midnight's Install
- yMidnite
- Real Name: Jim
- Radio: Galaxy DX-959
Midnight's Install
I have been taling about the pedistal mount that was in progress... Not as far done as I would have liked, but I have pictures:
Mount built and assembled on bench.
Aproximate mounting position (from driver view)
Pieces painted.
Remaing to be done: run wires/cable from under dash to mount (trim an solder), screw down mount, connect and check. Hope to get it done this week... depends on weather.
Pieces painted.
Midnight Rider / 989 N FL
"We preserve our freedoms using four boxes: soap, ballot, jury, and cartridge." -- Anonymous
In Memory Of:
Marek Sajczuk 1/7/05 - 6/18/05 - My Son
Joe "Hawk" Sajczuk 6/22/42 - 3/15/90 - My Dad
In Memory Of:
- Slim Pickins
- Handle: Slim Pickins
- Real Name: Paul
- Call Sign: VE1PEW
- Radio: Realistic Navajo 457
Re: Midnight's Install
Looking good. That amp looks familiar. Can't wait to see her all lit up
Paul
Paul
73,Slim
Insanity is hereditary......you get it from your children.
- Handle: naildriver
- Real Name: Larry Jensen
- Antenna: wilson 1000
- Radio: Galaxy 949 cobra 148
midnite
Thats a great looking bracket. It gives me some ideas for my truck. I have a ford ranger and there is not any room under the dash, or not a good place with a stick shift. That mount would work between my seat and shifter. Looks Great.
Weedge
Weedge
- yMidnite
- Real Name: Jim
Thanks for the compliments.
Wedge... it is amazing the lack of "dash" space that I have in my truck. Good luck with your design.
In Memory Of:
In Memory Of:
- likes2grill
- Real Name: Dan
- Radio: Midland 79-290
That is a great looking piece of workmanship there yMidnite, very good.
- yMidnite
- Real Name: Jim
I hope to have pictures by this evening. I have it all wired in and mounted... just need to clean up a few wires and it will be done.
In Memory Of:
In Memory Of:
- yMidnite
- Real Name: Jim
I finally finshed the little bit of clean up on the wires. School started this week, plus work, and the two year old... Saturday morning is the only time I had to finish.
You will see coming from under the dash the power, ground, and coax, I am not sure what I am going to do with that (maybe wire loom or something). I orginally was going to route it under the carpet (that is why the hole is in the back of the mount), but when I went to go do that I noticed it was rather warm under there. I decided I did not want to "cook" my cables, although it probably is no hotter than the roof.
Anyway here are the pictures:
Power is fused off the battery running an 8 gauge amp wire kit. Power runs into a fuse block which spilts to the radio and the amp. Radio is triple fused an the amp is double fused (prior to the fuses on the inside). I need to replace the one 30 amp fuse on the radio side of the fuse block with a smaller fuse (currently is a 30 amp), I will drop it to atleast a 20 amp but would prefer to put in a 10 amp if I can find it. Also the fuse under the hood is a 60 amp and I want to make it a 40 amp.
Lastly, I was looking at Gunny's site now that it is back up... I may (eventually when money and the nerve to drill holes in the roof) change my mag mount to one of those pucks.
In Memory Of:
In Memory Of:
Great job, I love the mount, just add some 'snakeskin" loom. Very good work.
- Slim Pickins
- Real Name: Paul
- Call Sign: VE1PEW
Great looking setup Midnight. I love seeing other people's installs. It can give you so many ideas for ways to install in different situations. It is nice that everything is visible from the driver's seat and within reach. Those fuse blocks are nice too and nice to have located where they are easily accessible.
73s
Paul
73s
Paul
73,Slim
- likes2grill
- Real Name: Dan
Setup looks great. Nice and neat, sounds good too. It was nice talking to ya the other morning.
1394
- yMidnite
- Real Name: Jim
Thanks All
Not quite my style, but it gets the brain thinkin'...721HACKSAW wrote: just add some 'snakeskin" loom.
It was good talking to you. I did not think that anyone else would be up that early.likes2grill wrote:Setup looks great. Nice and neat, sounds good too. It was nice talking to ya the other morning.
In Memory Of:
In Memory Of:
- armrdsaint
- Handle: Armrdsaint
- Real Name: michael
- Antenna: 102'ss
- Radio: cobra 29LTD, 29 NW
That is a very nice looken set up ! I am impressed and like to see peoples ideas come to life. Be proud and catch ya on the site someday. AUDIOSSS from Nebraska
LOUD-N-PROUD
- Radio Pig
- Real Name: John
- Antenna: Pigs Tail
Thats awesome! Nice work. Now you have given me an idea similar to yours for mounting in my Chevy silverado. That would make it much handier to use the radio while driving. Thanks for the idea!
Let us know how it all works out.
- yMidnite
- Real Name: Jim
Ease of use is great... everything is at your finger tips.Radio Pig wrote: Let us know how it all works out.
Few things that have come up:
Depending on the location of the sun, the chrome reflects into the passangers eyes and can wash out the display
Vibration or shaking - I used tech screws to secure it and these do not pull it tight enough
To fix the shaking I will use (I can't think of the name) a threaded insert that works like a rivet and then I can tighten the mount to hopefully pull the shake out.
Good luck with your install.
In Memory Of:
In Memory Of:
- Hondarider
- Handle: Nick
- Real Name: Nick
- Antenna: A99
- Radio: Cobra 29, Royce 632
Wow that looks sick! Looks pretty sturdy too. Best of luck with it.
Have a good one.
Hondarider
Have a good one.
Hondarider
Hondarider
- BobCB
- Real Name: Bobby
- Antenna: A99, Browning BR-140
- Radio: Cobra 25LTD(varies)
Gives me some ideas as well. I'm thinking of a few different options for putting a better radio in the Merc instead of just a 75-822.
854/BigDog in Central Alabama
- rattlesnake
- Real Name: chris
- Radio: cobra 29 nw classic
- rattlesnake
- Real Name: chris
- 015reddog
- Handle: 015reddog
- Real Name: REd
- Antenna: Coathanger
- Radio: Mudduck Junk
