Hello,
I use two mics for my RCI 2970n2 for the base. A Tup 9 base with a 10 DA SSB head and a D104 Silver Eagle. Does anyone know if there is company that makes a switch box (tow mics to now radio)?
Thanks
Mic Switch
- 325 lasvegas
- Handle: Starfire
- Real Name: Steve
- Antenna: IMAX 2000
- Radio: RCI 2970N2
- jessejamesdallas
Re: Mic Switch
PM sent...
Re: Mic Switch
Here is a topic on building something like you want, http://www.cbradiotalk.com/vi ... DE+MIC+BOX , it looks like you will have to contact ChopperDave through a PM to get the pics, for some reason they are no longer posting on the topic.
That type of box isn't hard to build since the radio doesn't require a contact on receive, only need 2 mic jacks, microphone cord, and a box to install it in.
- 325 lasvegas
- Handle: Starfire
- Real Name: Steve
- Radio: RCI 2970N2
Re: Mic Switch
Thanks for the replies. I will look into this. MFJ sells a mic switch box, but I'm not paying $109.00.
- jessejamesdallas
Re: Mic Switch
I think the one MFJ has is also a 8 pin hook-up.325 lasvegas wrote: ↑February 8th, 2018, 2:20 pm Thanks for the replies. I will look into this. MFJ sells a mic switch box, but I'm not paying $109.00.
