Does anyone know the wiring for the JCD-201M for a Uniden Grant XL? There is VERY little info on wiring for this mic.
Bill
Falcon99v@sbcglobal.net
JCD-201M wiring for Uniden Grant XL
- Falcon99V
- Real Name: Bill
- Antenna: Smokin Joe Gun II
- Radio: Galaxy 2517
Re: JCD-201M wiring for Uniden Grant XL
Here is the wiring on the 8 pin socket on the back of the mic, both are this way, BTW the wiring diagram in the manual is wrong.
1 (E) Shield – Ground
2 (M) Brown – Mic audio
3 (P) White – Ground
4 (G) Green – PTT +
5 (U) Black – UP
6 (D) Yellow – DOWN
7 (C) Blue – UP/DOWN Ground
8 (B) Red – 5-9 VDC power +
Now the problem is it won't be able to wire to a Uniden Grant XL (5 pin mic). It is designed for ham radios or a CB radio that has relay switching on the transmit. The way to check that is to unplug the existing microphone, if the radio doesn't recieve (the speaker goes blank) it won't work. Sorry to give you the bad news.
4 (G) Green – PTT +
5 (U) Black – UP
6 (D) Yellow – DOWN
- Falcon99V
- Real Name: Bill
Go figure! I will have to wire it for a different radio.
Thanks for the info!
I believe it would work on any of the Ranger RCI models, most of the Galaxy models too, and of course, ham radios.
