Sadelta Mike
- smoke blower
- Handle: East coast broadcaster
- Real Name: David Sadler
- Radio: Cobra 2000
Sadelta Mike
I have a Galaxy Sadelta Mike and it has that terrible hollow echo in it I was wondering can I just wire up a echo board in the Mike itself will that work off the 9v battery
Re: Sadelta Mike
If it's a desk mic there is another potentiometer inside to change the timing.
- smoke blower
- Radio: Cobra 2000
Re: Sadelta Mike
I took the Sadelta apart but I didn't see a pod to turn
Re: Sadelta Mike
Undoubtedly there was a manufacturer change, you could try changing resistor values for the timing and the cap by the mic element to change the audio response.
- smoke blower
- Radio: Cobra 2000
Re: Sadelta Mike
Ok thanks alot I will mess with it and see what I can change. Another problem with these desk mikes to is they pickup everything in the background no matter how far down I turned the gain down.
Re: Sadelta Mike
It is just like any amplified mic, the trick is to turn the gain on the radio up then adjust the gain on the mic, most turn the mic wide open and then adjust the radio's gain, that is why they get background noise.
- jon6667
- Real Name: jon
- Antenna: dipole
- Radio: icom 7300
Re: Sadelta Mike
anyone remember the Sadelta bravo desk mic. it has no echo it does have the beeps.
just wondering. i have one i pulled out of the closet. put a new foam cover on it. ive had it for many years. i think ill spray the contacts and put it back in service.
Re: Sadelta Mike
I've been looking for a Sadelta ME-3 hand mic, think it had the best sound of them all with a close second to the Astatic 575M6. There was also a Sadelta MR-1, same as the ME-3 but had a RB.
- jon6667
- Real Name: jon
- Antenna: dipole
- Radio: icom 7300
Re: Sadelta Mike
its a bravo plus sorry
-- Monday, 01 August 2016, 11:54 AM --
i like the sadelta bravo one because it has no echo. i hate echo. i can tolerate beeps. but i have a hard time hearing echo. it makes the person sound awful. i dont mind a little echo. bit it seems everyone wants to crank it wide open.
