Mike wiring
- CYBERWARRIOR
- Real Name: Freddy Garcia
- Antenna: Dipole
- Radio: Uniden 980
Mike wiring
Hi everyone:
Can someone please tell me the wiring for a Turner Super Sidekick by wire color,for a Uniden 980SSB ?
Needless to say,I have a few less hairs on my head !
- dgbacb4148
- Real Name: David g.
- Antenna: shakespere Big Stick
- Radio: Uniden Washington
Re: Mike wiring
Welcome to CBRT Freddy from Georgia Dawg country, glad to have you. You might check YouTube video's, or Google.... Good luck and jump in often.
David g.
David g.
- Handle: Boogieman
- Real Name: Bombero
- Antenna: 2ft Wire hanger
- Radio: RCI 2950 Mirage
Re: Mike wiring
Hey..
Here's a Turner mic wiring guide.
http://www.cbtricks.com/mic_m ... g_book.pdf
As far as the Super Sidekick to 980SSB =
1.Yellow audio hot
2.Black RX switching
3.Red TX switching
4.No connect
5.Shield
6.7.8 VDC phantom power for power mic with need of ext. power or N/C
Save it to your favorites...you'll use it often.
Bombero
1.Yellow audio hot
3.Red TX switching
4.No connect
5.Shield
Bombero
383 Boogieman
Re: Mike wiring
Just to add make sure the "Relay/Electronic" switch on the bottom is set to electronic. The audio wire on the sidekick is white.
- Seaview
- Real Name: Freddy
- Antenna: Patriot 1/2 wave
- Radio: Uniden 980SSB
Re: Mike wiring
Ok I found out this: 1-white 2-shield 3-black 4-red. This setup works but,2 things are wrong.
First I have to have it on relay,if I try to go to electronic when I press the bar to talk,it starts to change channels by itself !
Second I get audio but,I also get one hell of an audio feedback !
Perhaps this helps
Perhaps this helps
Re: Mike wiring
That is not the wiring for the Uniden Bearcat 980, is it the 4pin to 6pin adapter cable that comes with it? The wiring Bombero posted is for the radios mic jack, not the adapter. Changing channel is something strange since the mic jack isn't setup to do that function.Seaview wrote:Ok I found out this: 1-white 2-shield 3-black 4-red. This setup works but,2 things are wrong.
Perhaps this helps
- Seaview
- Real Name: Freddy
Re: Mike wiring
I have no idea then. The wiring he says is for 6 pinjack,I only have 4 pin plug
Re: Mike wiring
- Seaview
- Real Name: Freddy
Re: Mike wiring
I got this radio,as a refurb from Uniden.I am still clueless as to the wiring.
Someone on another topic sent me this:
1-White
2-Red
3-Black
4-N/c
5-Shield
6-N/C
I ordered a few 6 pin plugs,hopefully I will be able to finally wire it right.
1-White
2-Red
3-Black
4-N/c
5-Shield
6-N/C
Re: Mike wiring
- Seaview
- Real Name: Freddy
Re: Mike wiring
Sorry is very hard for me to keep track of posts.
