D104 4 pin to 5 pin
- fiddlehack
- Mud-Duck Jr.
D104 4 pin to 5 pin
Hello, I'm sure this question has been answered here before, but can't find searching, I have an old Uniden Washington SSB, an old CB buddy from back-in-the-day, gave me his old great D-104, Uniden is 5 pin, D-104 is 4 pin, adaptor I bought transmits but no sound thru radio, I assume because of mic wiring circuitry, any easy fixes or opinions?
Thanks so much-Brian
Re: D104 4 pin to 5 pin
Hello fiddlehack,
Welcome to the forum. Sounds like the mic is not wired right or possibly a broken wire, I've also ran across some adapters that were wired wrong too. Depending on the age of the D104, it could be wired for a relay switching radio, is it a 4 wire mic or 6 wire mic? I would go buy a 5 pin mic plug and wire it for the Washington, this is for a 6 wire microphone, pinout goes,
1 - white (audio)
2 - shield ( mic ground)
3 - black (RX)
4 - blue ( switching ground)
5 - red (TX)
If it is a 4 wire mic you have to jump pins 2 and 4 but some radios this will just make it squeal on transmit.
As a new member could you post an intro in the "Welcome top the Forum" topic, http://www.cbradiotalk.com/viewforum.php?f=89 , so others can say "hello", thanks.
1 - white (audio)
3 - black (RX)
5 - red (TX)
- Rabbit Ears
- Handle: Rabbit Ears
- Real Name: Cliff
- Call Sign: WW153
- Radio: RCI 2995DX CF
From what I hear from you is that your radio is a five pin, YES.
Okay.... let us assume it is a electronic switching radio.
MDYoungblood gave you the correct pinout for your radio.
1. See that you have a fine battery in your mic.
2. If battery OK.... check the wires inside of the mic to the plug on the cord with a DVM on the ohms setting. (It could be a broken wire in the plug or the plug miswired).
3. Here is a picture of a schematic I modified for a 4-pin (Cobra). Or the 4-pin plug was even wired for Midland, not Cobra.
PInout for Cobra to Washington
1-Audio to 1
2-Shield/ground to 2 &4 (jumper pins)
3-TX to 3
4-RX to 5
Here is a schematic of a D-104 and MY schematic of my D-104
I did clip the white wire that "grounded" the audio during RX.
1-Audio to 1
3-TX to 3
4-RX to 5
USA FOREVER
RCI 2995DX CF (PRIMARY BASE)
Turner Super Side Kick
BIRD 43P
HY-GAIN SPT-500 antenna
BIRD 43P
- fiddlehack
- Mud-Duck Jr.
Gentlemen, MDYoungblood & Rabbit Ears, thank you so much for the response/info, I apologize, I'm sure this is common knowledge to all here and a "lazy person" question from me...yes! LOL...I have been out of Radio for many years and looking for easy answer haha....I am terrible at electronic wiring but I guess I will have to open things up and try to figure it out. Thank you Rabbit Ears for the schematics, I think that will be of great use. Thank you both again.
- Rabbit Ears
- Real Name: Cliff
- Call Sign: WW153
No problem, that is what we are here for friend!!
USA FOREVER
BIRD 43P
BIRD 43P
- Space Ghost
- Handle: Space Ghost
- Real Name: Ash
- Antenna: A pair of dipoles
- Radio: 148GTL/Washington/Grant
Great information, great information.
I have a question related to wanting to use a 5 pin set up but some terms need translation.
What is: PTT Ground, PTT, MIC Ground, MIC Input? This in relationship to the Cobra 5 pin wiring, please.
(yes sir or ma'aam. I understand ptt to be push to talk)
Thank you.
Thank you.
The microphone element ground is usually tied in with the switching ground on most application but the 5pin where the two grounds are separate. Most times a squeal happens when tied together. Using an older 4 wire microphone there are a couple things to try to prevent the squeal, a "Tee pad" is one. You can find the info to make one on CBTricks microphone section. Most times it will be found that a 6 wire microphone will be best to use.
Brian, a belated welcome to the forum. I have basically the same set-up as you. You can order through one of our sponsors on thi forum. You will need...........Adapter - Convert a 5 pin SSB CB mic to 4 Pin Cobra Uniden CB Radio - Workman C5P4C. It was a simple installation. 3's to you/yours from Georgia Dawg country, and good evening.fiddlehack wrote:Hello, I'm sure this question has been answered here before, but can't find searching, I have an old Uniden Washington SSB, an old CB buddy from back-in-the-day, gave me his old great D-104, Uniden is 5 pin, D-104 is 4 pin, adaptor I bought transmits but no sound thru radio, I assume because of mic wiring circuitry, any easy fixes or opinions?
- fiddlehack
- Mud-Duck Jr.
Thanks Southwind, and other great experienced user replies, much appreciated, I've bought a few adaptors and have same problem, but like I do, just throw more money at it, I bought a Galaxy 2547, unit is great and functions exceptional. Old D104 4-pin plugs right in a works great. I'm running this unit barefoot with a simple solarcon a-99 and have good results, in fact what's suprising, this thing receives 11 meters WAY better than my Yeasu 450d with G5RV long wire dipole? Anyway, any recommendations for a beginner level amplifier for the Galaxy?
I have a 4pin Cobra/Galaxy to 5pin Uniden/Cobra and it was wired wrong, I took it apart and they used a diode in the mic ground, it was interesting, rewired it (TX/RX was backward) and it works fine.
