Texas star dx 400 v
Lakotawalker
Radio: General lee cobra 29
Antenna: Maco v 58. Monkey ma
Cell Phone: 6158097800
Texas star dx 400 v
Post by Lakotawalker » Thursday, 14 July 2016, 6:03 AM
Looking to hook up ts 400 v for base use how big a power supply do I need, will be using a General Lee radio same as Connex 3300 thanks.
(edited by MDY)
Re: Texas star dx 400 v
Post by sonoma » Thursday, 14 July 2016, 6:18 AM
I run a 450V some times and I use a 30 amp power supply to run it so it has a little head room when running. the lee uses a 5 amp fuse. so figure both together would need about 30 amps just to make sure it has plenty of amps so you are not maxing out the power supply. this way it would run longer with out making the power supply to get hot and wear out faster. if I run a mobile and amp together I have a 50 amp power supply I use to make sure it has plenty of amps to run both. you could get by with a 25 amp power supply but it would be running full max out put.
one way you can also check what you need is to see what size fuse your radio and amp has in them and add the amount together then get a little larger amp.
drdx
Post by drdx » Thursday, 14 July 2016, 8:40 AM
Figure about 10 amps per 100 watts on a tx star. Their site rates it at 40 amps. But, depending on how you run it you could use a smaller supply but go ahead and get a 50 amp or more and be done with it.
Post by MDYoungblood » Thursday, 14 July 2016, 10:14 AM
I won't run an amp and radio on the same PS. I would get one for the radio about 20A, (10A minimum) and look for a good 50A for the amplifier, you never know when you might upgrade.
Base
Uniden Washington
Mobile
Texas Ranger TR-696FD1C
Handheld
Maxon HCB-40WX
Antennas
Avanti Sigma II
Lakotawalker
Post by Lakotawalker » Thursday, 14 July 2016, 10:25 AM
Thanks guys 50 amp it is you guys are the best
Post by MDYoungblood » Thursday, 14 July 2016, 10:28 AM
Look for a quality PS,, better to spend the money now then to have to spend more later, I like Astron.
Base
Uniden Washington
Mobile
Handheld
Maxon HCB-40WX
Antennas
Avanti Sigma II
drdx
Post by drdx » Thursday, 14 July 2016, 11:01 AM
Good point on the separate supply. I also like to have a totally separate supply to just testing radios and tinkering. It seems way safer than having a mishap and damaging other equipment and you don't have to unhook your main setup just to test a radio. I also have a separate meter and dummy load setup, freq counter, extra mics as well, it makes for a handy shack for sure. You don't have to get it all at once. Just keep an eye out for bargains and let it grow over time.
Lakotawalker
Post by Lakotawalker » Thursday, 14 July 2016, 11:12 AM
Ok fellow cbrs I've got a few items belonged to my pop from back in the day, I've got to go thru it all eventually :cheers: and see what is there
