Alternator help
Rabbit Ears
Radio: President HR2600
Antenna: Sirio 27 tornado
Home Phone: 307-674-1541
Alternator help
Post by Rabbit Ears » Wednesday, 19 February 2014, 8:05 AM
I've got the standard alternator on my 1996 f250 7.5L.... Can I kit that alternator for higher output. I'm pulling an RV. I can do the work.
Help....!
Read the Constitution.
FREEDOM and USA FOREVER
STAND UP FOR THE FLAG!!!
President Grant DX four button (1983 model) PC-999 *in my truck*
President HR2600 (PRIMARY BASE)
President HR2510 (backup base) *solar powered*
K40 magmount
Microphones: Turner +3 *two of them* Turner Super Side Kick
Palomar TX-150 amp
RM Italy KL300P (A/B modded)
BIRD 43P
Sirio Tornado 27 5/8 wave antenna
alfred56
Radio: galaxy 98 vhp
Antenna: sirio p5000
Re: Alternator help
Post by alfred56 » Friday, 21 February 2014, 5:37 AM
What do you mean by kit it. You cab get one I have on from an online source in my 84 200a for no plan on adding another
Sent from my DROID RAZR using Tapatalk
Logged in via: iPhone
Re: Alternator help
Post by MDYoungblood » Friday, 21 February 2014, 19:51 PM
I not sure they even make rebuild kits anymore but I remember them from years ago. The kits (bearings, brushes, etc.) had new diodes and rectifier bridge and they did increase the amperage some but you are using the same windings. I think it would be best to find a rebuilt unit, they almost have twice the stock amperage.
Base
Uniden Washington
Mobile
Texas Ranger TR-696FD1C
Handheld
Maxon HCB-40WX
Antennas
Avanti Sigma II
Homemade Full Wave Loop
Homemade 1/2 wave Dipole
rickk
Radio: Galaxy DX979
Antenna: Francis/**NON-SPONSOR**
Re: Alternator help
Post by rickk » Sunday, 27 April 2014, 18:51 PM
NAPA often has HO alternators in their books.
If you are pulling an RV, sounds like you would be driving lots of miles. Plenty of time for charging. Your circumstances might be unique but wondering why you need more alternator output? Most high current needs are intermittent use.
Might possibly be better to spend money on a bigger primary battery and also install an auxiliary battery. Anderson Power Products makes a nice, efficient, painless-install battery isolator if needed. There should be a ton of room on your right side frame rail to put a really big auxiliary deep cycle battery. The RV I would assume has plenty of room for batteries as well.
Do you need more power when you are driving, or need more power when you are parked?
Rick
Rabbit Ears
Re: Alternator help
Post by Rabbit Ears » Monday, 28 April 2014, 20:26 PM
Yes, I'll be getting the bracket and the larger alternator. Will also be using a pair of Trojan T105 wired in series for the camper. The old 1996 F250Hd 4x4 has a tow kit. When I turn the key off, that isolates the camper from the truck.
I'll go dual Optima AGM batteries in the front end of the truck. Tough and spill proof too. That'll do quite nicely for the work lights and the KC lights.
K40 magmount
Palomar TX-150 amp
BIRD 43P
