new 8 pill amp
euffsaid
Radio: cobra 29
Antenna: wilson 5000
new 8 pill amp
Post by euffsaid » Friday, 15 November 2013, 13:11 PM
if I got two extra batteries for the truck with my stock alt that does 160 amps will it be able to run the fat boy 8 pill?
543FtWorth
Radio: (non-sponsor) 29 LTD
Antenna: *Censored*
Re: new 8 pill amp
Post by 543FtWorth » Friday, 15 November 2013, 14:09 PM
You will have some voltage drop but it will run.
Re: new 8 pill amp
Post by jessejamesdallas » Friday, 15 November 2013, 16:59 PM
lights might dim...
Ohio_359
Re: new 8 pill amp
Post by Ohio_359 » Friday, 15 November 2013, 17:07 PM
That amp has the potential of drawing more current than your alternator can produce, then you start drawing from the batteries which has a maximum potential of 12v, then your alternator has to start working to charge your batteries and run the amp, etc, etc, it just snowballs. Best to have enough alternator to do the job which is easier than lugging around 500# of batteries, which again only have a 12v potential.
euffsaid
Radio: cobra 29
Re: new 8 pill amp
Post by euffsaid » Friday, 15 November 2013, 19:11 PM
Thacks guys I guess I'll go ahead and get a bigger alt
EC 174
Re: new 8 pill amp
Post by EC 174 » Thursday, 21 November 2013, 20:49 PM
jessejamesdallas wrote:lights might dim...
This
screen name
Re: new 8 pill amp
Post by screen name » Friday, 22 November 2013, 11:19 AM
What do you drive that has a 160amp alt? I drive a diesel pickup and I think mine is only around 135 or so.
Ohio_359
Re: new 8 pill amp
Post by Ohio_359 » Friday, 22 November 2013, 12:25 PM
screen name wrote:What do you drive that has a 160amp alt? I drive a diesel pickup and I think mine is only around 135 or so.
I've got a 3rd generation Dodge/Cummins and I think the stock alt is rated at 136a.
North Texas Mudduck
Re: new 8 pill amp
Post by North Texas Mudduck » Friday, 22 November 2013, 15:14 PM
yep will hae voltage drop along with lights dimming of coarse
might try and keep the daedkey of the 8pill around 250 to 500 and let it swing and see what happens
euffsaid
Radio: cobra 29
Re: new 8 pill amp
Post by euffsaid » Friday, 22 November 2013, 15:54 PM
I will I also ordered a 300 amp alt I will get it in a week.yay
North Texas Mudduck
Re: new 8 pill amp
Post by North Texas Mudduck » Friday, 22 November 2013, 20:31 PM
where you get a 300 amp alt at???
euffsaid
Radio: cobra 29
Re: new 8 pill amp
Post by euffsaid » Saturday, 23 November 2013, 7:22 AM
There not a sponsor here. But it mkm customs for my ford f-350
Re: new 8 pill amp
Post by jessejamesdallas » Saturday, 23 November 2013, 18:33 PM
Problem with most 300 amp alternators is they don't put out much at idle...To get the full output you'll have to keep the motor rived-up...Another problem with some high output alternators like that, is once they get hot, your amps might drop quite a bit...
When I ran a 8 pill I had dual alternators...The factory alternator and a 200 amp alt. This set-up never had to have the engine's RPM's rived-up and never dimmed the lights...To run a 8 pill right, your going to also need a driver (pending on the radio) So first do some math and see how much amperage your going to need to supply your 8 pill, the truck, and driver...I would also double check with the alternator manufacturer what that 300 amp alt is suppose to do at idle speed...Some barely do 100amps, if that.
200 and 220 amp alternators usually will have quiet a bit more output at idle than the 300+ Alt's.
Only other thing you would need to be sure you do is up-grade your charge wire off the alternator to the battery. If your charge wire off the alternator first runs to the computer, add a second wire off the alternator straight to the battery...
Way I did my Suburban was I ran a new charge wire to the battery off the alternator, disconnected the original wire from alternator to the computer...There's still a original wire that runs from the battery back to the computer up by the radiator...Doing it this way you get more juice from the alternator to the battery first which is where you will also have your power wire from the amp connected.
543FtWorth
Antenna: *Censored*
Re: new 8 pill amp
Post by 543FtWorth » Saturday, 23 November 2013, 18:49 PM
X2. There's no replacement for displacement. Unfortunately it's a pain to fit a large case alt in some vehicles.
