FarmeroBrown
- Radio: RCI-2980
- Name: Bill
- Home Phone: CBRT# 19293
Post
by FarmeroBrown » Friday, 11 January 2013, 20:24 PM
OldFuelInjection.com Has these 3G Alternator up grades for my 93 F150, mine has a factory 95A but some cars with heavy draw had 130A-these are 160A.
They fit back to '88 and go on up past '93 . they idle at 100 amps says the websight. Can use same bracket with some grinding. $130
I Wonder if the volts could be tweeked?????????
Just thought I would share!!
Edited by Slyguy
Farmer
p38
- Radio: magnums9 /madison
- Antenna: 102 whip
- Name: Jonathan card
- Cell Phone: 4012062673
Post
by p38 » Saturday, 09 February 2013, 21:04 PM
yes they can! you have to mod the voltage regulator.they usually put out 14 volts or a little more 15/16 is the cut off point usually. do the reaserch on the regulator and step it down a touch. they might sell ones for the purpose of racing.!check out MSD
Jack of all trades ,master of none
ASE certified technician
my radios -cobra 25ltd /cobra 29ltdX2 /trc-501 / 1977 president madison am-usb-lsb/ magnum deltaforce 10meter /stryker 955hp magnums9 . imax 2000/ 102whip /k40 mag mount aracher crossbow 3 element on the flat side.
North Texas Mudduck
Post
by North Texas Mudduck » Sunday, 10 February 2013, 9:21 AM
you can have a adjustable voltage regulator installed but anything over 14.5 then you take a good chance of heating up the battery or batteries and boiling them
the reason for more amperage is so the amp will hold up just by turning up the voltage wont help getting a bigger alternator with more amps will help
February 10 2013
need a little more info on what kind of pickup
93 ford f-150 is there a model name or something
you can go alot bigger than a 160 amp alt
- Moderator
- Logged in via: iPad
- Radio: Uniden Washington
- Antenna: Avanti Sigma II
- Name: Greg
Post
by MDYoungblood » Sunday, 10 February 2013, 11:15 AM
Have you checked out the sponsor "Nations Alternators" to see what they could do for you and when you call tell them you are a member. The sponsors forum plug doesn't work so here is their website.
http://www.nationsautoelectric.com/" onclick="window.open(this.href);return false;
PS, batteries really don't like anything over 14.2 volts
23 AM "WORLD
WIDE" 38 LSB
Base
Uniden Washington
Mobile
Texas Ranger TR-696FD1C
Handheld
Maxon HCB-40WX
Antennas
Avanti Sigma II
North Texas Mudduck
Post
by North Texas Mudduck » Sunday, 10 February 2013, 18:12 PM
We can custom build your EXTREME AD-244 ALTERNATOR set up for external regulator and wire
harness to run to the 911-02R regulator in your vehicle interior or wherever you like it.
