mazda volts
fat boy
Name: lucas thibodaux
Home Phone: 9854382334
mazda volts
Post by fat boy » Monday, 11 April 2011, 19:37 PM
is there some type of variable voltage regulaor that i can install in my 2001 mazda protege to get around 15.5 to 16 volts would that voltage hurt my electronics?
Re: mazda volts
Post by 'Doc » Tuesday, 12 April 2011, 4:55 AM
Most fairly late models of all vehicles typically have the voltage set around 14 volts (not exactly, just close). Gaining an extra volt would probably have more of a detrimental affect on the vehicle's electrical system than any particular benefit for your radio.
I don't know about other places but locally we have an alternator/generator repair shop. They can make adjustments of the voltage regulation to suit the vehicle/owner's preference. They will set the voltage to almost anything the customer wants, but after a certain point they don't guaranty their work, so it's on the customer's 'back' if it 'swarms' on them. Typically, raising voltage beyond some point will mean a reduction in the life of things, mainly light bulbs from my experience, but anything connected to that voltage source. I've also found that that can sometimes be more trouble than it's worth! It's up to you though, so...
(Once changed from a 6 volt positive ground to a 12 volt negative ground. Made lots of things possible that weren't before that change. Also found out that I had to do some 'reverse' wiring to get things to operate 'normally'. If I had to do that again I still would, but I'd do some more planning ahead of time. ;))
DirtyfaceDan
Re: mazda volts
Post by DirtyfaceDan » Wednesday, 13 April 2011, 7:13 AM
You can get Marine charge regulators that are variable, and are built for charging larger battery banks in shorter periods, such as wet NiCad industrial type batteries.
