225 amp mega fuse.
225 amp mega fuse.
#296416
Post by 626 »
Just a quick pic of my mega fuse and holder. The wire is 1 gauge. The fuse is 225 amps. It sits on a bracket I fabricated. It protects the wire run where it passes through the firewall.
Each piece of equipment is also fused individually.
DixieEcho82
Real Name: Greg
Radio: RCI, Galaxy, Uniden
Re: 225 amp mega fuse.
#297432
Post by DixieEcho82 »
Very nice. Just curious, what model of vehicle is that?
yankee
Mud-Duck Sr.
Mud-Duck Sr.
Handle: Yankee
Real Name: Jim
Antenna: Dipole
Radio: Yaesu browning cobra and others
#297433
Post by yankee »
Looks lik a jeep. Maybe an older cj
#297434
Post by 626 »
That is a 1991 Jeep Wrangler
Those fuse holders are really very cool. They function as a junction block as well, you can connect several pieces of equipment. I use it because I have a cable running through the firewall and anytime you have a junction like that its a good idea to protect it with a fuse. Keep in mind that the fuse protects the jeep from burning down. Not the equipment
For the record, its an older YJ and the body is really similar to a CJ7
rv_camper
Real Name: RV
#352903
Post by rv_camper »
I like the fuse setup, but I'm a little concerned about the current carrying capacity of the wire.
According to my charts, the 225 amp fuse you have is oversized for the 1 gauge wire. Is it possible you're actually using 1/0 cable?
You're not going to be drawing a continuous 225 amps, so I really don't see an overload condition heating the wire significantly, but you may be getting unnecessary voltage drop across the wire depending on the length.
#353569
Post by 'Doc »
If it were me, I think I'd use a slightly smaller fuse/breaker than 225 amps. The size of cable isn't an issue, it's as large as the starter cable so I would think it ought'a handle anything you are likely to have as an electrical accessory. I don't think you need to run out and change the size of that fuse! ...unless you are going to give it to me, naturally...
